C6 Vendor for Sale Exclusive forum for vendors to list C6 products, services and promotions.
Nick williams 102mm throttle body on sale and in stock at juiced!!!
Old 01-10-2018, 10:18 AM
0JUICED1
Former Vendor
JUICED1's Avatar
Default Nick williams 102mm throttle body on sale and in stock at juiced!!!
Nick Williams Performance drive-by-wire throttle bodies are CNC precision-machined from billet aluminum to meet the demands for increased airflow on the drive-by-wire LSX performance engines. The 102mm throttle bodies require an aftermarket intake to fit the larger diameter throttle blade. They use a 6-pin late model connector that works with late model wiring harnesses. Tuning is required for installation; and the Nick Williams Performance drive-by-wire throttle bodies come complete with stepper motor and electronics installed—no need to disassemble your factory throttle body.
102MM DRIVE-BY-WIRE LS THROTTLE BODY
102MM DRIVE-BY-WIRE BOOSTED LS THROTTLE BODY (FOR CARS MAKING SERIOUS BOOST)
Old 01-11-2018, 11:22 AM
0JUICED1
Former Vendor
JUICED1's Avatar
If you want to make big power you'll really need to open that intake up
Old 01-12-2018, 04:23 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Great upgrade
Old 01-13-2018, 04:20 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Big performance
Old 01-14-2018, 01:44 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Eventually the stock throttle body will become a bottle neck
Old 01-16-2018, 11:22 AM
0JUICED1
Former Vendor
JUICED1's Avatar
When you want to make serious power you need to open up that intake
Old 01-17-2018, 08:28 PM
0JUICED1
Former Vendor
JUICED1's Avatar
You can't make big power without one of these
Old 01-18-2018, 11:21 AM
0JUICED1
Former Vendor
JUICED1's Avatar
Nick Williams 102MM TB
Old 01-19-2018, 11:22 AM
0JUICED1
Former Vendor
JUICED1's Avatar
If you plan on running over 15lbs of boost you'll want the Nick Williams high boost 102MM
Old 01-20-2018, 09:35 AM
0JUICED1
Former Vendor
JUICED1's Avatar
Anytime you're looking to make serious power these are a must.
Old 01-21-2018, 09:54 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Top quality units
Old 01-22-2018, 10:24 AM
0JUICED1
Former Vendor
JUICED1's Avatar
This will work for LS2, LS3, LS7 and LS9 powered C6s
Old 01-23-2018, 11:22 AM
0JUICED1
Former Vendor
JUICED1's Avatar
Nick Williams 102MM
Old 01-24-2018, 03:32 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Big time flow numbers
Old 01-25-2018, 11:14 AM
0JUICED1
Former Vendor
JUICED1's Avatar
These require a tune because the are a big time mod
Old 01-26-2018, 10:38 AM
0JUICED1
Former Vendor
JUICED1's Avatar
A must with aftermarket intake manifolds
Old 01-27-2018, 12:48 PM
0JUICED1
Former Vendor
JUICED1's Avatar
If you want an aftermarket intake you'll want one of these too.
To Nick williams 102mm throttle body on sale and in stock at juiced!!!
Old 01-28-2018, 01:47 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Wicked performance gains
Old 01-29-2018, 10:51 PM
0JUICED1
Former Vendor
JUICED1's Avatar
Get that 102MM monster
Old 01-30-2018, 11:34 AM
0JUICED1
Former Vendor
JUICED1's Avatar
These 102s make big power
Quick Reply: Nick williams 102mm throttle body on sale and in stock at juiced!!!
