AutoX content: Z51 A-Street setup
Back into the fray (had a '15 Z51 previously in SS) with my new (to me) '16 Z51. 3LT M7 w/ Comp seats.
The car is completely stock, other than base 18/19" rims & a 265/305 Bridgestone RE-71Rs. This time around, I went w/ a good bit more front camber (-3) & -1.5 rear. It's lowered on stock bolts & corner-weighted (perfect 50/50 w/me in it).
This car also has Mag Ride, so first time experimenting w/ this (other car had standard Z51 suspension).
Maiden event w/ it was yesterday. The lot we run on is small and has terrible grip--almost like it's damp, compared to regular asphalt. It was also cold (for FL) & I didn't have a co-driver, so not a good barometer yet.
I lost by 1/10th to a very well-driven AWD 911 C4S (AWD cars rule on this lot due to their acceleration grip). My car was the fastest rear-wheel drive car there & also 3rd in PAX out of 102 cars.
Had the latest iteration STR Miata the past year. FANTASTIC AutoX car & won me a big championship in '17, BUT...
SO psyched to be back in a C7--and WHAT a difference from the Miata lol.
Some pics & vid:
Me in the car (~1/8th tank), and lighter Forgeline rim street setup--add 14 lbs for the AutoX setup:
[url=https://flic.kr/p/DRkoJM]
[url=https://flic.kr/p/22qzTef]
[url=https://flic.kr/p/23vfx2Z]
The latest base rims clear the Z51 brakes:
[url=https://flic.kr/p/DRk9uK]
Vid (my passenger enjoyed the ride lol):
Some pics & vid:
The following 4 users liked this post by GTB/ZR-1:
daleong (01-17-2018)
WoW!! Terrific picture
GTB/ZR-1 (01-17-2018)
Speaking of tire choice; when I first got me '15 C7 in early '15, I ran a 245/275 setup. The 265/305s setup is MUCH better lol.
I just wish the base C7 had at least stock 9.5/10.5" wheel-widths. The 8.5" fronts especially, leave a lot to be desired to run in Street.
You are now my guru on my Z-51 set up!!
I read your information on C-7 setup a week ago but this really helps. I ran 18 x 9.0 TSW front wheels on my C-5 setup, had not thought about checking to see if they clear on the C-7. Can't recall the offset. TSW makes a 19x10.5; may go that way if my front wheels work.
I live in Colorado and the Pilot Sport run flats are a waste, even on 50/60 degree days. Guess they will be my street tires until I can wear them out.
Our first event is in April so Keep us snowbirds up to date on your success!
Bob
Bob
GTB/ZR-1 (02-02-2018)
Bob
Bob
Good luck
Some pics & vid:
https://www.youtube.com/watch?v=T2Ij1Il0zAc
Some pics & vid:
I had a great year last year in A Street with almost the same setup as you. By mid year last year I was getting some firsts or usually second overall in Pax out of up to 140 competitors. If a certain well setup and well driven Mustang GT was there it was second. He's a great driver and F Street Pax is so much softer i would have to beat him by around a second in raw time. He beat me out in both the Street championship and the Overall championship but still had a great year.
I have the 8 spd paddle shift auto instead of your manual 7spd and was one size wider in tire at 275 RE71s on the front. I was at -2.5 camber on front and 1.9 rear. I found that at -2.5 the inside of the fronts were often hotter than the outside. Have you monitored that yet? Also, have you decided that 265 on front is supported better on the 8.5" rim and therefore it gives you better grip than stuffing a 275 on?
Note: The new base wheels do clear the Z51 rotors but only just on the front... so for anyone going to this setup keep in mind that the balance weight placement on the outside of the rim is critical or they will hit the rotor.
Good catch but...
But thanks, could have saved me an expensive mistake.
Good luck with the new Vette this year!
I figured the 265 would be as far as I should go w/ the 8.5" rim. I'm trying -3 & am monitoring how it works--need more events to tell.
Good luck this upcoming season--although I'm thinking your months away from starting--because... Canada! lol (I'm originally from upstate NY, just off Lake Ontario--so I understand ;-)
rplanddeck- we have a good group of people w/ an NCCC club in the area. I need to reconnect w/ them. I think my car would be a very strong 1A (?) car. Have fun!
Received 8,928 Likes
Well, I go to track track mode, turn everything off (can't do that starting off in sport mode), then twist back to sport mode. I did that because I believe the Mag ride in sport will be more compliant than track. The surface of that lot needs a softer setup to have any hope of maintaining traction out there. I'm sure I'll run it in track mode on a better surface.
In Sport 1 I had PTM working coming off the corners and I could really go hard on the throttle as I came off the apex. I could hear PTM modulating the power to the rear wheels to keep them from spinning too much. Don't know if PTM will work for you in your autocrosses but it might be worth a shot to see if it could help.
Bill
GTB/ZR-1 (02-09-2018)
Z-51wheel weights:
Once I move back out of track mode I lose anything set up in track mode. Although I am only familiar with pushing the button twice and going to the sub modes, Wet, Dry, Sport 1, Sport 2 and Race. The only autocross I did in my Z06 I used Sport 1 which gave me great runs as I was able to garner FTD at an NCCC autocross.
Bill
Bill
Black: F 24.4 lbs. Rear 27.5 lbs.
Chrome: F 27.5 lbs. Rear 29.8 lbs.
Any idea what the wheel weights will be with stock 18/19' wheels?
Wow--nice job! That's great work w/ the A8, since it only tops out around 64 in 2nd, as opposed to 72 w/the M7.
Being above the 49th parallel does mean some cold in the winter but the west coast is much milder than anywhere else in Canada. Much more rain than snow. So we actually start up the regular season in late March and go until mid to late October. We also have a "slush" series that goes through the winter but the Vette is not great in rain and cold temps so I rarely participate in those. The 4 wheel drive guys rule that series.
Good luck in the rest of your season and report back on how your camber testing goes.
Cheers,
Clive
GTB/ZR-1 Awesome car! Current NCCC rules put ZR-1 in 1SN (Group "'1" for stock car/no mods, "S" for street tires over 140 tread-wear and "N" for performance class. With Hoosiers, leave the "S" off. With mods, class moves to Group 2, "2N". Have fun!
The nice thing about NCCC AX is that there are usually 4+ Corvettes in most classes which makes it fun.
Bob
Bob
