Z06 grill not very good at keeping out leaves
Noticed a real pile up between the two radiators yesterday, piled up where the two meet. I'm guessing no gap between them to let them pass through. Might want to check what's piling up in yours.
LOL . . . a leaf blower of course.
Actually, the fact that the z06 grille allows more debris through to hit and clog the radiator is one of the reasons I will never change the stock Stingray grille. When I do get a few leaves on the radiator, I use a brush to remove the bugs and debris, then either vacuum out with extension or pick it up with a loop of masking tape on a stick.
Gonna have to say I'm going to make an extension for my shop vac, while the leaf blower sounds like the ticket because of course they are leaves there is no way to get behind enough to blow them out. Both corners have big leave, the entire bottem filled with the smaller FL oak leaves.
Ok while I do realize cleaning out this area is a little OCD, I emptied out my shop vac previous to cleaning it out to see what accumulating in there...
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
Elmer
I'm afraid to look!
Just ran across this, and thought, Yikes!
https://jalopnik.com/owl-stuck-in-su...-be-1822243727
"And, by God, if you suspect you might have hit one, maybe pull over and check."
Ya think?
Ya think?
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Never even looked in there on my ‘14. No problems of any kind in 4 years of daily driving.
See! We agree!
However, you didn't dispute that the holes in the OEM grill don't stop trash from hitting the radiator. For the grill to function as a trash stopper, it'd need to be like the "no see-um size" screen that I have on my back patio. Even if you had that screen on it, what stops stuff from going into the hood louvers?
Me thinks we shall be going down a very large rabbit hole discussing trash infiltration on our cars and the radiator blockage it entails.
Thus, I'm back to my opinion! Going up in the mid 60s today! Time to take the car out for a trash vacuum run!
Elmer
Received 2,093 Likes
Ya think?
Ya think?
Received 3,439 Likes
Unless your stock grill has a screen attached to it, I don't think it's going to do a great job of keeping trash out of the radiator either. I'll clean out the debris when it is causing an issue. The Z06 grill kicks the stock grill's *** when it comes to looks.
Elmer
Elmer
Are you saying that this ^^^ is what you vacuumed out of your grille? Maybe someone just emptied a shopvac in there... I found two leafs in my Z06 in two years... that’s a leaf a year
Yes, car had less then 3k on it at this time, about 3 months old. The cigarette butt is a nice plus.
