Painting rock chips
Painting rock chips
Have a 14' Stingray that has a few rock chips on the nose and two on the drivers door. Want to get those areas repainted but have been warned about paint matching. It only has 18k miles and is always garaged, can't imagine there has really been any color fade and wouldn't think with today's technology it would be too hard to match up but thought I would see if anyone has had it done.
Popular Reply
01-19-2018, 01:03 AM
For only a few small chips, it would be time well spent to try touching them up yourself with $30 worth of tools available on Amazon...
How to video - rock chips at 4:08 -
Moderator
The biggest problem you might have with a quality paint shop would be that they probably can't duplicate the level of orange peel that you may have. LOL. If you are considering touching it up yourself, you may indeed have color matching problems, depending on the color you have.
Seriously, I've had some difficult paint colors matched perfectly.
DALE#3 (01-19-2018)
Rayrider7 (01-18-2018)
The following 8 users liked this post by jimmbbo:
Bob Beroza (01-19-2018),
bosco1 (01-19-2018),
csysman (01-19-2018),
Highplains (01-19-2018),
OC Sadler (01-19-2018),
and 3 others liked this post.
rock chips
You have a choice here. A few little repared spots that only you can see/know where they are or whole areas where everyone can see the mismatched paint? Sometimes leaving things alone is the answer. Now, if some bad driver takes off the front end of your car the answer is obvious.
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
That said, I can certainly sympathize with the OP on the "but I still know they are there" problem...I share that disease as well.
Another vote for drcolorchip. If you want a shop to repaint then contact your local Corvette Club for recommendations.
Most major cities will have people who tour used car lots doing touch up on their inventory. A lot of these use an air brush technique and achieve amazing results without doing major panel paint work. You might contact high end used car departments or the better detail shops to get a reference.
Rayrider7 (01-19-2018)
Dewayne'sZ06 (01-19-2018)
I've used Dr. ColorChip with great results.
Have a couple on my Crystal Red 2014... got ACDelco lacquer touch up paint pen (code 89U WA 505Q 19328531)but haven’t used it yet... Will keep Dr. ColorChip in mind...
How to video - rock chips at 4:08 - https://www.youtube.com/watch?v=Uz-zW-cLdUs&t=319s
The paint “brush” the guy uses in the video is a cool idea. Ordered one today. Thanks for posting.
I always start with the OE paint touch-up kit, and so far it has matched most cars well. In the case of my LR it matches well with just the right amount and size of metallic flake.
Dr. ColorChip is great; I have it in both Arctic White and Carbon Flash for my C7.
I have an ink lettering set that has been hanging around for years. It has nibs like those used in the video. They will do the same job!
I have been trying to give the lettering set away for many years. But with computer printers able to do the job today, no-one wants an old inking set. I just pulled it out of my junk box and will give it a new life - filling corvette rock chips.
John
Another vote for Dr. Color Chip. I used their product on my Lt. Carmine Metallic 98 coupe. It was a perfect match. Be sure you follow the instructions carefully and I recommend that you watch a couple of Youtube videos on the product as well.
