leaded or unleaded
1st Gear
leaded or unleaded
just got a 68 C3 and wondering about gasoline or additives for the leaded gas no longer available. What do I do if I cant find, probably cant, leaded gas?
I dont know if the valves have hardend seats or not. The guy I got it from put 100 or so miles on it in 20 years and he doesnt know.
Received 1,469 Likes
Cruise-In II Veteran
You'll be okay with unleaded fuel.
Received 2,127 Likes
Another old BS tale. Have yet to see damaged valveseats from unleaded gas. But the sale of the snake-oil, LEAD substitute in a bottle continues.
I have seen sunken values where I attributed it to prolonged use (Daily driver) of unleaded. If you drive sparingly then I would not worry about it.
Aren't the exhaust seats of a post 72' head induction hardend anyway?
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
I think it's 71 and on. But he bought a 68.
As I understand it, you don't have to worry about hardened valve seats unless you are loading up the engine a lot, like towing, or at a constant high rpm like in a boat or airplane.
Neither octane nor ethanol have anything to do with the myth of protecting the old valveseats. And the more ethanol the higher the octane. Ethanol in itself is 113 octane.
73racevette (01-23-2018)
Without lead the valve seats will slowly erode. That's why they started installing hardened seats and valve rotators when they took the lead out of our fuel. With that said, you may be all right if you don't drive the car much, or very hard. With my '66 I used Red Line Lead Substitute. Cheap insurance.
Thats the myth all right. Thousands of pre unlead cars still out there running with millions of miles and no valveseat issues. H-m-m-m-m-m-m. And how many decades ago was lead removed?
I agree. I ran heads on my 468 that had closed chambers and they didn't have hardened valve seats....never had a problem. The only time I could potentially see an issue is in extreme cases where a lot of spring pressure is experienced on the seat. That could potentially cause issues eventually. I personally never had a problem.
HeadsU.P. (01-22-2018)
Back in the late 60 s and 70s , Amoco sold SUPER PREMIUM Fuel at its stations.. it was a high grade premium, 95 Octane if I remember correctly, and it was UNLEADED.. ZERO LEAD.....We all ran that stuff in every car we owned .. many of them only knew WOT or off.. a couple with 11 and 12 :1 compression.. We never had a valve seat issue.. not one..
My point is, unless you're pulling a heavy trailer with your vette, you don't need hardened seats, or lead additive.
Valve recession happens when the engine is heavily loaded for long periods of time. I've seen it several times in older vehicles, once in a pickup truck that was used to pull a 10,000 lb trailer and twice in dump trucks.
