Removing hardtop
Removing hardtop
Rookie question time. 2009 base Vette with removable hardtop. I’ve only had it a month and today was the first I even thought about taking the top off and it is a beautiful day. Any tips/suggestions? Is it a two person job or can I do it myself?
Rogillio (01-21-2018)
Received 1,766 Likes
It's sure easier with 2 people. If you drop it on the pavement, you'll chip the paint (or worse). Could I suggest that you get a helper for the first few attempts and learn how to stow it in the back first? Once the two of you have it out, you can go to some grassy area and single-hand it just to get a feel for its weight and awkwardness. If you drop it on the grass, it probably won't get hurt.
But then again, I tend to wear a belt and suspenders
the kid C6 (01-22-2018)
Received 1,673 Likes
To me top removal is strictly a one man job.
ddame2 (01-23-2018)
Undo the latches, lift up the front and hold with one hand, then slide the pins on the back out of their sockets enough to get the other hand on that side, then pull and lift. It's not all that hard to do.
Just remember to secure the latches when you put it back on to avoid becoming a member of the FRC (Flying Roof Club).
Stick a pair of gloves in the back cuby.
In the summer time, the roof gets hot a hell, and easy to loose it when it starts to burn your hands as you are taking it off.
The following 2 users liked this post by Dano523:
ddame2 (01-23-2018),
Received 1,136 Likes
Top side up and front pointing forward. Stows in the rear area same orientation as when installed in the top.
Easily done by one person
Received 2,060 Likes
C6 of Year Finalist (performance mods) 2019
IIRC, the top has only been off 1 time after the first year. I had just cleaned the car and thought it'd be cool for a quick drive down the freeway. Big mistake. Just because you vacuumed the carpet, doesn't mean that all the crap is gone.
Do not do it in the garage. I have read too many posts where someone has hit their garage door or garage door opener in the process.
easy
Easier to do with 2 people, but not at all difficult by yourself. Just be aware of the bulkiness. It's not heavy, but it is awkward. Release the latches, 2 front, one rear. Lift up the front, move it forward slightly to clear the rear pins and lift it up. Snaps cleanly into place in the rear hatch.
Note-Open the rear hatch BEFORE removing the top. Then you can just move to the back and place the top inside.
Always remove and replace the top in an open area, not inside the garage, around other cars etc. it's very easy to bang the top into something or even into your own can. Watch out for the open hatch lid.
Place the front of the top into the hooks toward the front of your hatch, then press down the rear of the top to snap into place. Very secure.
If you have a Removable top, don't be afraid to use it!
The following 3 users liked this post by DLove25:
The easiest way to remove the top by one person is to pull it down from inside the car and tilt it toward the back of the seat. Get of the car while sliding the top over your head. Once out of the car, you can slide it out of the open door and get a handle on it the towards the center to balance it.
Then you can carry it to hatch.
Only had it out twice. To noisey with top out. Especially over 50.If you do take it out experiment with putting windows up partway to cut down on buffeting.
Wow, I can't believe how many people with coupes don't want to use their targa tops. When I had mine I had my top every chance I could find, and it didn't matter where I was going or what speed I was driving. I loved every second!
odd (01-21-2018)
