TPMS help!!!
TPMS help!!!
New sponsors on all four wheels. Trying to get DIC to go into relearn mode with no joy.
Fire up car and gof the Service Tire Monitor System and clashing warming light. Toggled to Ifo screen then Tire Pressure screen (no pressures displayed) then pressed and held Select button for at least 10 seconds and got no horn beep. Car won’t go into relearn mode.
Thoughts?
Thoughts?
Received 8,926 Likes
Thoughts?
Thoughts?
Bill
Yes they will relearn. Just drive it some.
What the two guys above say. That's what I do. Works every time.
The tire shop had programmed the RFID code in the sensors to a C6, instead of C7. Once the sensors were re-coded to C7, and the DIC was put into TPMS learn mode, the sensors paired immediately. (the car honks one time as each sensor pairs to the car). Had tire pressures showing while still in the service bay..
DavidC83 (01-23-2018)
Problem solved.
Let us know how those work out. I much prefer the OE sensors that are designed specifically for our C7 Vettes - they have a centrifugal sensor in them to determine the direction of rotation in order to help determine which side they're on during automatic pairing, and in addition to pressure they send the temperature to the TPMS module so the temp range can be displayed on the DIC.
Those generic sensors may transmit that data to the TPMS as well - is your DIC displaying the temperature range like our OE C7 specific sensors do below??
Oooooohhhhh - you got some generic sensors!!!
Bill
Our C7 sensors are made by Schrader, as all the C6 and C5 sensors have been.
You may be able to make out the part# in the picture of C7 sensors below - GM part#13598775. Our C7 sensors have some special features, one of which is the centrifugal sensing feature that sends the TPMS direction of rotation so the TPMS can tell which side of the car the wheel is on. I'm not sure generic sensors will do all the things necessary to do the automatic relearn procedure. As MacRoadie said, the tire shop had to use a TPMS tool to do the relearn procedures and get the sensors logged into the TPMS module memory. After having used magnets on the C5 and a TPMS tool for more than 10 years with my C6 Vettes, I'm glad when I swap on different sets of wheels for street or track that with the C7 I just put them on, drive, and the new set of sensors automatically log into the TPMS.
And what allows that automatic procedure to work are the OE sensors - they are the ones to use!!
Just MHO, YMMV!!
Bob
Found GM part# 13598775 by acdelco in rockauto https://www.rockauto.com/en/parts/ac...)+sensor,12036
GM:
(All parts included? seems to be missing one part?)
Cheaper by about 10 bucks vs GM? Which one would you go with?
GM:
Received 1,981 Likes
And...... OEM sensors are reasonably priced. Not like the C5 that we’re like $100 a corner.
Id not bother with anything else.
