drivers seat is shiny
Hi all. hope someone has some ideas on what to do with the driver seat in my 07. the "leather" is very shiny compared to the pass. seat, which has hardly been sat in. Is there anything that can be done to get my seat to look like the other seat? (short of buy two new seat covers)
If I'm guessing correctly, and the leather on your driver's seat has been polished by butt friction of sliding in and out (as well as around) on the seat, no, there's nothing that you can do. If the leather is just dirty, then yes, you can use some elbow grease and a good cleaner to remove the sheen.
Keep in mind that stock seat skins are plastic-coated leather, so leather cleaners and other leather-specific products will do nothing but smear on them, and then will get on your clothes.
1st one is the pass. seat, next one is my seat
Received 2,683 Likes
2018 C6 of Year Finalist
It's shiny because it's dirty. I've used the Leatherique system on real leather seats with great results. Supposedly it works on the vinyleather **** we have in our cars but I have no personal experience.
Honestly, if it were me, I'd pull the seat, then pull the seat base out and remove the skin from the base. Then I'd use a diluted mix of Simple Green and a soft brush on the seat skin. Soak first, then scrub.
It might sound like a lot of effort, but it's really not that hard or time-consuming to pull the seat, then pull the base off.
A damp cloth and a drop (or less) of dish detergent (or other mild soap) is a good way to to clean it. "Rinse" with several applications of damp only cloth to make sure to get all the soap removed.
Make sure your cloth is only damp not wet throughout the process. It may take a bit of elbow grease, but this is safe, and will remove the sheen as well as clean effectively.
I forgot to mention, on dirty Cashmere stitching, you can use a Q-tip dipped in Hydrogen Peroxide (3% in the brown bottle). Makes the stitching look new.
Received 3,066 Likes
Your seat bottom has lots of creases in it and it's shiny.
Do like I did .... Ordered a new driver's side seat bottom cover from GM and installed it myself.
While I was at it, I also installed a 'heavy duty' seat bottom foam I purchased from:
http://www.shop.djmotorsportaccessor...8&categoryId=1
Now both seats look exactly the same.
Disclaimer ... I am no upholstery expert
__________________________
With that said, here are my thoughts on all of this:
The seats in the C6 are partially covered in leather, while other sections of the seat are covered in vinyl, so what works on part of the seat may not work on other sections of the seat.
On the sections covered in vinyl, a strong cleaner like Simple Green should clean it up real good. On the sections covered in leather, cleaners and conditioners made for real leather would be your best bet.
A product that softens and conditions leather is really needed to keep the leather soft and supple ... however vinyl (plastic) just can't soak up these conditioners like real leather, and would not benifit from it.
Bottom line for the OP .... His driver's seat bottom cover is cracked, worn, shiny, and basically looks like **** in comparison to the passenger's seat bottom .... Best fix is just to replace that old ugly seat cover with a new one from GM (not expensive either).
