Ears sore from new helmet -- will that break in?
My new Simpson Carbon Devil Ray is causing my ears some pain/soreness after 15-20 minutes of wear. They turn bright red and are really being smashed into the cheek pads. I do wear a headsock, FWIW.
When I put the thinner cheek pads in (25 vs 20mm), the pain is gone, but then the fit of the helmet gets sloppy: I can rotate the helmet too easily and the pads barely even touch my cheeks.
Should I expect the cheek pads to crush and break-in from wear, or is this a sign the helmet is too small? Everything else seems to fit well, especially the all-important crown area, and I even called Simpson to ask. They claim it will break in but by then it would be used/non-returnable if they're wrong. I asked if this is a sign the helmet is too small, and they said no.
For the record, my older Arai doesn't have this problem but it's obviously well-worn and probably broken in. I don't remember having sore ears from it but my memory from back then isn't that good.
Too small ... I do not believe it will break in. Put a pair of shoes on that are a 1/2 size too small and try to break them in ... ain't going to happen.
You may get used to it but that is a different thing I think.
If returnable now I would definitely do that and try again.
I forgot to mention that I had originally bought a larger size but the fit was sloppy, so I returned it and went down a size. I was kinda borderline to begin with (right at the small end of XL, or the large end of L).
I have found that it is imperative to try on many helmets to feel which ones are most comfortable and fit properly. For me, Simpsons pushed too hard on my forehead as did one other helmet I owned.
Not all shells and internal foam are shaped the same on all brands, and not all of our heads are shaped the same. It is best to try on several brands and models. You will know when you get the right fit. For me the best fit is Zamp, but that does not mean it will work well for you.
Yep, understood. That's why I said the fitment is fine everywhere else. Shame, it's a really nice helmet.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I would not argue the size is too small, but rather the shape is not correct for your head. I used to have a Simpson that gave me headaches. Then I went and tried on a bunch at a local store and settled on a Bell because the fit was best.
^2 .. I got the best fit with a Bell also
Yep, understood that helmet shells and the interior padding are different shapes between the different manufacturers. As I said, the overall fitment of the helmet is good everywhere else. It passes all of the usual fitment tests, including the most critical one around the crown.
I was just asking how much break-in I can expect from the pads around the ears, if any.
Otherwise, try on different brands of helmets and find one that's shaped more like your own head.
I agree. I have slightly modded helmet padding in the past when I start feeling pressure after prolonged wearing of the helmet.
Ear bright red...maybe you not getting a "point by?"
Is there any reason you can't try a 20mm pad on left and 25 on right? 5mm is not going to make the fit assymetric.
Have you tried a thicker headsock with 20mm pads?
I had a devil ray. Great helmet. I just don't have fit problems. I 've been happy with
devil ray
stilo
gforce
stand 21
bell
I think with a bit of thought you can get anything to fit but sure if you just pick 3 off the shelf 1 will feel better than the others.
devil ray
stilo
gforce
stand 21
bell
Received 8,928 Likes
Bill
