Black box above gas pedal
Cruising
Ok it has been determined that I have a problem inside the black box above the gas pedal. The voltage from it to my blend door motor isn’t right. I’ve read about cold solder joints inside this box going bad. I need to know what I’m looking for inside this box. Does any one have a picture or a good description?
There are two resistors in the box that overheat and damage the board. They are 2 watt when they should have been at least 3W. If you change the resistors and solder jumpers over the damage it should be fine. If you look at eBay item 192271083570 you'll see the area that overheats.
Beware that the vacuum connector has a little nut in the middle holding it on.
