Aftermarket trans cooler location
So I am looking to see what others have done as far as location and mounting of an aftermarket trans cooler with fan.
Thoughts and pics appreciated.
I installed mine behind passenger side driving light and by passed the the side tank in radiator.search threads in FI&Nitrous and you should be able to find pictures there
I eliminated fog lamps and installed the coolers there transmission in passenger side and engine oil on the d/s with 8 inch fans as not enough air gets in true those openings but there's plenty of room.
Opened a 6 inch hole in front of the tires to relieve air pressure from that area and let hot air out. text for pics 305-457-3066
I have fans turning on @ 160 degrees, Summit has a 8" fan draws only 4 amps and blows 2400 cfm
Using -6 an cooler and light Russel's blue trace pro classic hoses.
http://www.russellperformance.com/mc...oclassic.shtml
https://www.summitracing.com/parts/prm-19128/overview/
Riq (06-26-2018)
Riq (09-13-2018)
A couple good ideas in here (post #13 & #21, but #21 requires coilovers): https://www.corvetteforum.com/forums...on-cooler.html
I did what xboostx did. Added trans and oil coolers up front. I removed the driving lights.
trans temps dropped 40+ degrees whil racing. That’s huge
oils temps say lower. 245 max under heavy racing conditions.
amazing what a little extra air cooling can do
I used the same part + location and it did not work for me. Ran it with + w/o the fan, in the rad and out. None of them cooled trans sufficiently. Was getting in excess of 245*F in 70*F ambients and above 260*F above 80*F. Replaced B&M with a 2 stacked plate Setrabs (50-619-7612) and now max out @ 235*F in the 80*s. Stacked plate type is a must. Build quality of Setrab seems a fair amount better when you view them side by side. IMO, get the better quality and do it only once.
Good luck either way.
Originally Posted by turboffr
Read through this. https://www.corvetteforum.com/forums...for-13-gs.html
No need to re read it. All I'm saying is if the B&M can work great for me it should for anyone. I don't know why you said it doesn't.
Originally Posted by realcanuk
Too long. I remember when that thread was going on.
I never said it didn't work. I posted in that thread with pics of my install and results. I was posting this link for the OP to read
No worries. I maybe misunderstood you're post. Thought it says you tried them and changed them out cause didn't cool well.
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Terry (TKOGTO) is a road racer. Drives the tires right off his GS and I've seen it first hand at Watkins Glen. So his experience is likely being reported on a race track. And I agree with him.
For those of you that have a trans cooler, what do you think of this Setrab 9 series 20 plate set up ?
https://www.ebay.com/itm/SETRAB-OIL-...0/391630361945
