MSD 2 Step wiring question
Hello,
I haven't seen many topics covering my question.
What do you connect the Blue/White wire to?
I found this post:
https://www.corvetteforum.com/forums...sd-2-step.html
PK /WH wire on circuit no. 1035
It looks like they connected the pink/white wire to the blue/white wire.
My question is - do you put a switch in between the MSD unit and the pink/white wire on the clutch position switch?
When your launching from the starting line to you activate the 2 Step - Pop the clutch - then have to turn off the system as your shift to the next gear?
I'm worried about the system reactivating when you go into second.
I found this post:
For anyone that finds this thread - I just finished up the install of my MSD 2 step.
On my 2005 C6 Corvette - I ran the blue/white wire from the MSD box to the Purple/White wire coming out of Pin B on the lower Clutch Position Switch.
The wiring diagram for LSX Revival has it as a pink/white wire - but on my 2005 it was Purple/White.
I have tested the 2 step - and it works when you push the clutch pedal in.
You can either unplug the 2 step box - or add in a switch to turn off/not complete the circuit to disable the 2 step for when you don't need it.
