FS: ★Quiet Down Your 14-18 Interior in Seconds!! / Blockit Sound Deadener - FREE S&H!!!!!
Premium Supporting Vendor
Location: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
Order Now and Received FREE Shipping & Handling!! The Box is large so you save BIG!
Get rid of unwanted noise in your interior in SECONDS with the BLOCKIT™ "Quick & Quiet" System!
NOW WITH EVEN MORE BARRIER FOR EVEN MORE NOISE REDUCTION!
The BLOCKIT™ "Quick & Quiet" mat is the fastest efficient sound deadening system available. It installs in seconds!
Simply place the 3 piece kit right over your existing factory carpet! One piece for the cargo area and one piece for behind each seat. All pre cut for a perfect fit!
The patent pending design absorbs and suppresses unpleasant noise that leaks into your interior.
This is NOT a thin single layered mat. The BLOCKIT™ is a unique combination of 4 infused layers of real acoustical soundproofing. Now with even MORE barrier for more noise reduction.
It measures 1" thick! It can compress down to 1/8" so you lose NO cargo/trunk space!
It helps reduce tire, road noise and some aftermarket exhaust. But not to worry your exhausts sweet note will still come through when you get on it..
Great for Blue Tooth. Allows you to have a comfortable conversation. Helps reduce driver fatigue that occurs on long trips.
The BLOCKIT™ also helps reduce heat and keeps your cargo area cooler.
Since there is no adhesive you’re not gluing weight permanently to your car. Take the Blockit out for track events. Install for the ride home.
The BLOCKIT™ for the 14-18 Corvette has the "hoop cut outs" so you can still use your cargo curtain.
The durable UV protected top layer looks great and allows you to still use your cargo area. Feel free to place an aftermarket cargo mat on top!
So quick so efficient, we had filed for a patent!
3 Piece System 1 large cargo and 1 for behind each seat.
Picture below shows the piece behind the seat. Undetectable once in position.
___________________________________
Securely order online!
Coupe: Fits all Stingray, Grand Sport & Z06 http://www.tkoperformance.com/2014-1...upe_p_420.html
Convertible: Fits All Stingray & Z06's
http://www.tkoperformance.com/14-17-...ble_p_395.html
Any Questions, feel free to call us! 1800 778 9898
Some feed back from forum members...
I installed the 3 piece system and finally got a chance to do a test drive this evening. I was very pleasantly surprised how well it worked as the improvement was immediately noticeable. The noise level inside the cabin was reduced and I had to lower the radio volume since it was so much easier to hear. I can still hear the nice sound of the engine & exhaust, but without the annoying road noises. Very pleased with this purchase.
I installed the Blockit sound insulation mat and the behind the seat panels this weekend and I am very impressed. The mat just goes in the hatch area and the fit is excellent. I installed the two panels that go behind the seats behind the carpet. The carpet in that area is not tacked down so it is easy to do.
The mat looks very polished in the rear cargo area so I don't think that I will add an aftermarket cargo mat on top of it.
While commuting to work this morning on the freeway I really did notice a difference. I did not have to crank the radio way up and the voices and music were much clearer.
If you are looking for a real easy sound insulation solution I would recommend this product.
I just put one in my '05 coupe. The difference in interior sound was instantly noticable. After cranking it up I had to put the window down a little to make sure the engine was running OK.
It did however, take me double the 30 second recommended install time, due to me flopping it in there upside down and then having to take it out and flip it over because I didn't read the instructions.
I got mine yesterday and installed it last night.
First drive to work this morning and I can tell you it makes a big difference. Those that say it doesn't must have some really frickn' loud exhausts.
It took the resonance away that the road puts through the rear hatch area (hatch floor, plastic) and the road noise from the tires is probably cut in half.
There's also a noticeable "quietness" inside the rear now that I never had before. I always had that "white noise" behind my head from all the noises coming from the rear hatch area. Now it sounds like the entire car is quieter.
It made such a difference I am no longer worried about putting dynamat or peel and seal in my car. I will however still do the peel and seal on the floor boards under the car because now that the rear is so much quiter I hear road noise from under the car... lol.
Overall, it's a great buy and I'm glad I bought mine!!
To start with, I am not a vender and do not sell these things, but WOW! What a difference. I have an 05 vert with borla stingers and love the sound. But on the interstate and highway speeds, the car is just kind of loud. Not just from the exhaust, but from road noise. So I bought the new "blockit' insolation kit sold here on the forum. Not the kind that requires you to remove the carpet or anything. Just put two pads behind the seats and one pad in you truck, or cargo area for a coupe. I drove my car at 70+ MPH for a good ways last night and WOW!!! Much smoother and peacefull sound. The stereo sounded better and the car just seems so much quieter in the cab area. I have had a C6 coupe and now have a C6 vert, and I promise you, this thing works! Just wanted to shout out a nice mod.
I was at Carlisle and the Blockit was sold out, so I bought the demo kit that was inside the Corvette parked under the TKO tent. In my opinion, it was worth it because it works. My C6 is very loud, as it is cammed, etc., with headers & NPP. It has an annoying low rpm drone. With muffler flaps open it is unbearable for cruising below 1,950 rpms. Even with flaps closed, the drone was very annoying below 1,950. Most of my cruising is between 1,700 and 1,950 rpms in 6th gear with 4.10 gears. With the blockit installed, the drone is gone at these rpms with flaps closed. Not just reduced, but gone. Below 1,700 drone is reduced to a bearable level.
With muffler flaps open the drone is reduced with the kit, but still louder than my comfort level. But it's a moot point now.
Having had Blockit in my Z06 - I thought it did a great job reducing noise so I added it to the C7 - Z51.
It arrived packaged well. Easy install with a precise fit. I was able to use the rings and shade. I found it able to make a nice noise reduction on all surfaces around Little Rock including interstate and different road surfaces including concrete and asphalt.
I'm very happy with the product!
Installed on my C7 Z06. TRANSFORMATIONAL! The reduction in tire noise is astonishing. Being an engineer I had planned to use my laboratory dB meter to measure noise levels with and without the TKO Blockit kit. As it turns out there is no need to do so because the noise reduction is truly dramatic. This kit is a "must have" for all but deaf C7 owners. I had a '14 Z51 which had hellacious tire noise. I was exhausted after driving it for 3-4 hours. The '15 Z06 was significantly quieter and rides more smoothly....think Chevy vehicle engineers softened the suspension bushings. Seems to be well known that the '15 is a quieter car. Just can't believe how such a relatively inexpensive and easily installed kit can be so effective. I could now drive the car across country....yes, it's that good.
Well, I had a chance to test drive my car on some roads that previously had some serious tire noise due to the road conditions. For the ease of installation and simpleness of the product; I'm very pleased with the it. I was able to lower my radio volume from where it used to be, and hold conversations without raising my voice. In fact I am now aware of other noises that I hadn't previously heard.
So bottom line: I'd recommend(your hearing my vary) .
I can't say it's equal to the kits that require full interior dis-assembly since I didn't do that, but I definitely feel there is value in the product. If you are in Southern Calif and want to try in your car, come by and we'll throw it in and you can hear for yourself. Or just take my car for a test drive.
Tom
Tom
Received my set of sound deadeners yesterday and promptly installed them in about 10 minutes.
Started the car in my garage and could hardly hear the exhaust with the windows up. Backed it outside ( a lot of snow here now ) and tried the same thing, windows down ,windows up. I will not get to take the Z06 out until spring, but I can tell you that there is a substantial difference in the noise factor just sitting in the car and listening to it run.
Great product. Can't wait to do a more extensive test in the spring, but initially this seems to be a great product !!
Many thanks,
Dave
Many thanks,
Dave
Just got my Blockit mats today and did a roadtest on the concrete I16 around Savannah and a couple miles on local black top.
Super easy install - drop in and forget it. I have a coupe.
Big rear mat had the slits for rings.
Put my Stingray logo rear carpet on top of the mat and also put the mats behind the seats.
I can tell a difference in noise ; can hear the radio better and believe a long cruise will be far more pleasant.
I have the Blockit mats. My wife can hear like you wouldn't believe. She is the perfect test for these. She stated to me that there was a significant difference in sound reduction. That's good enough for me. I thought there was a difference too, but I didn't want to rule out wishful thinking on my part so I had her listen before and after.
I put it in my 2016 Z06 last week and the difference is very noticeable. Less tire noise, radio volume setting is lower now and much more enjoyable. As another poster noted the exhaust sound now stands out more; my Z06 exhaust is normally set to track mode.
I did notice the action of the Bose audio pilot (auto volume compensation) is much more noticeable now and I turned it off.
obviously super simple to put install, in a 10 min trip to the store... noticeably quieter. i have LTH, high flow cats, and factory npp. to me it sounded like i had the flaps closed.. maybe even more quiet than that.
…… is it worth the $230?? to me yeah, because i am lazy don't want to pull all the carpet out.... so with that being said, money well spent to me
__________________
Serving The Corvette Forum For 21 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
Thank you for the orders! Tracking numbers will be sent to the email you provided.
Sorry sold out of Convertibles. Will have them back in stock soon
New Batch of Coupes arrived so they are in stock!
All order from monday ship tomorrow and friday! Tracking will be sent to the email you provided.
Thank you!
Thank you!
All orders from over the weekend left yesterday...
Emails with tracking numbers have been sent!
Thank you for you business!
That's why this sale listed is pretty good.
So the free shipping sale at this time is for the one item but not both. However I also stated you can call in and I'll trim off some$ off the shipping.
As I stated in my reply to your email, Fed ex, ups goes be dimensional weight. Which actually means size. The Blockit box is 36x12x12 The lloyds mat is similar. So Its costly to ship these.
Thank you
Sorry, not at the shop now (Saturday). I know we are real low in stock there was only a few left. Should go out Monday.
I have these in my 2017 GS and it is a great low effort way to cut down on the interior noise. Once they are in you forget they are there because they look so OEM.
Ed
Ed
So... are the 'Vert mats back in stock....LK
I received my Blockit kit last week and today I received it’s companion Lloyd’s cargo mat today. Everything fits and looks perfect. Best of all, I can really tell a noticeable improvement in road noise inside the cabin. I never measured the db’s before and after the install, but it certainly is quieter and more comfortable.
TKO Performance (03-10-2018)
Thanks for the update.... I am going to take some BEFORE Db readings on several patches of roads/streets and will compare them after I get the mats installed... I seem to remember that no one has done that yet, at least for the 'Verts!!??....If anyone HAS, please re-post them for us.......my EARS will tell me what I really want to know, but it never hurts to use instruments to validate your impressions...... LK
The problem is, if you use a phone app, you can short change the decibel number you receive for the DB drop.
Some phones have built in high pass filters. So the readings are inaccurate because of the low frequencies they are not picking up and will not be incorporated well into overall levels. The overall sound level is dominated by frequencies that a phone will not be picking up.
Even iphones without high pass filters still have issues when getting a true reading when using these apps.
That's why we read people experiencing more noise reduction with their actual ears. To us..that's what really matters.
As soon as we get them in, I'll get them out! I apologize for any inconvenience. Thank you very much for your business!
