FS: 388 ls7 de-stroked
388 ls7 de-stroked
This is engine rob had assembled and I purchased last year,, its in the car Yet still alot of work to do,. With the 2nd baby arriving in the middle of this I just underestimated how much time (or lack there of) is leftover to play in the garage,. Ill throw a Crazy deal out there to see it go to a new home and actually have it run... see Robz link of the parts,. I went with the updgraded Ti valves...
ill take a huge hit and let it go for $13k for the long block assembled
I would consider trade if anyone looking to swap out their ls6
https://www.corvetteforum.com/forums...-upgrades.html
its in the car and can send pics of the engine .. text four one zero 6937116
Ls1 sized stroke ., ls7 sized pistons
Ttt
ttt
Will consider ls6 trade ..
ttt
ttt
ttt
I trade you my long block AKA LS6
160 Degree Thermostat
LSXR Fast 102mm Intake Manifold
LS2 Throttle Body
FAST Fuel Rails Billet Aluminum Natural
GM Heads 799
Intake Valves 2.02
Exhaust Valves 1.57
Comp Cams XER273HR 224/230
Comp Cams Beehive Valve Spring and Retainer Kits 26918
Comp Cams LS Heavy Duty Rocker Arm Bearing Assemblies
Comp Cams Pushrods 7.350
Comp Cams Hi-Tech Roller Timing Chain 3153
GM LS7 Hydraulic Valve Lifters
GM High Volume Oil Pump
LS3 Oil Pan
https://www.youtube.com/watch?v=A83QnVqqhXc
LS2 Throttle Body
GM Heads 799
Intake Valves 2.02
Exhaust Valves 1.57
LS3 Oil Pan
Couldn’t play the vid., 799 heads sound from another engine intirely ., what bottom end is it ?
This engine as it sits assembled it too compressed to take any boost in ., parts are good for a re build to take more air though 👍🏼
Ttt
Ttt
Md Delaware
Ttt
Ttt
ttt
Ttt
