Front License Plate Bracket
I want something that is easy to take off and on. Has anyone tried this one from Mid America Motorworks?
http://www.mamotorworks.com/Corvette...-only-611843-1
I just got my license plates and when I opened the plastic bags holding the factory brackets, I found there was no instructions or hardware for mounting. I've been searching and the Top Flight brackets look nice but their website does not have instructions/videos for mounting to a Z06. Besides, from what I've read there are some screws underneath you have to reach. I have no way of jacking my car up to get underneath it; and I really don't want to.
Got a warning ticket from a local county cop here in Maryland just a few days after taking delivery of my new Z06. My mistake for not registering it out of state!
As for front plates, opted for the factory flush mount (not the "legal" monster") and it seems to work fine. No interference with the front painted bits and easily removed (Phillips screwdriver based on the plate screws I opted for) and fits fine.
Should you chose the same, mounting was simple- lock the "big" holder bits into the corners of the bracket, but I did need to slightly shave the corners of the bracket to get them to fit into place. Then set the bracket into the grille and push the large plastic "screws" into the holes. Will bottom out then give a slight twist with a Phillips screwdriver to snug up. Bend your plate a touch and mount, easy peasy...
Allen
Allen
SouthOCBoy (02-11-2018)
Allen
Allen
Top Flights bracket is a !st class product and takes 10 minutes to install. No jacking required.
Lay on the ground with a small ratchet and loosen about 4 of the screws, each side of centre that hold the front splitter on.
Remove the 2 screws closest to the centre and slide the bracket in.
Reinstall the 2 screws and tighten up the others and you are done.
Top Flights bracket fits between the splitter and body, so it isn't the lowest point at the front.
The picture in my avatar has the plate mounted to the aero plate, which was hard to get off when I got the top flight holder.
Oh oh, just read you want something easy to take on and off..
Even the aero plate that comes with the car is hard to get off at times.
A friend has a Sto & Sho on his car that removes in about 10 seconds..
I looked at those but it requires a bit more for original installation on cars with front splitters and hangs down below the splitter making it the low part at the front of the car.
Mine came with the car on delivery, along with the standard "big" mount just not installed. Two separate mounts including the associated mounting pieces.
If not, you may want to ping your dealership and maybe they would be able to assist...
Allen
Allen
i got the factory flush mount too. It was installed when I got the car I tried removing it but it looks like i would have to break those expanders the big plastic Phillip head screws go into. Have you removed yours after installing it. It’s a good fit but it does seem to block some airflow into the grill/radiator.
Allen
I got pulled for the same thing. It’s lame dude..
Account disabled by request 1 Mar 2018
Check the instructions available on that website. Click on the “Documents” link to see the PDF instruction sheets. Looks like a caveman can install with simple tools. Post up when you have the plates installed and please let us here know how it worked out.
SouthOCBoy, I have the bracket shown in your link. I live in LA and put it on every time I park on the street or in a public parking garage. It seems like tickets for not having a front plate are becoming more prevalent, especially among people being pulled over by the police (it used to mainly be parking enforcement officers). Anyway, the bracket is definitely pricey but top quality. It's really easy to mount and remove taking no more than a few seconds. Several sellers told me that it will stay on at highway speed. I don't doubt it, but I'm still hesitant to drive with it only 24/7 just in case it pops off and damages things. But I've driven around LA at 30-40 mph. Plus, it fits in the storage space in the left rear of the trunk. It seems like the only sturdy and easily removable mount that doesn't require screws.
Thanks, Rob
I also have this same front plate bracket. It does just clip onto the front grill using a spring loaded mechanism with moveable spring loaded tabs that hook behind the grill. Very simple and holds securely. It takes a good deliberate squeeze to release and remove the bracket. I don’t think it’s likely to release on its own from driving with it on. It also has some cushions that help avoid scratching the grill.
SouthOCBoy (02-13-2018)
I just bought the sto and show one and it works great. Fits perfectly with existing screws. No drilling and you would have to know the bracket is there to notice it when the plate is off.
Cruising
I have the same front bracket that South OC Boy showed in the link to Mid America. I purchased the same bracket from Zip last month. It clips on and off in a few seconds and I have no reservations about it coming off while driving the car.
I've been using this bracket for 6 years and it holds up very well. On a recent trip it saved my splitter twice, once on a pothole and once with debris laying in the freeway. I like the fact that it is the low point on the front end. If it gets damaged, it is a lot cheaper than a splitter.
