Cam Retainer Bolts Seized
Bow-Tie Guy
Finally got around to pulling old K110 out of block. Cam retainer bolts would not budge. An LS specialty shop changed cam out nearly 4 years ago and used the countersunk hole version of retainer plate. Top bolt was not fully seated. Took some forum advice & went with impact in lieu of steady pull. Bottom bolt came out but none of the other 3. Broke 3 impact T-40 bits & have started trying to grind one of them out with a dremel. It doesn't look promising. Don't know if bolts are too long, overtorqued, over-coated with locktite or what. I can't see any color residue on the one I did get out. The 2 end threads on the removed bolt appear flattened which echoes a post I read some place else. I also tried spining them out with a chisel/hammer & also a center punch. At this point only remedy I can come up with is pulling short block from top & taking it to a machine shop. Heads are already off & at AHP.
If anyone has any ideas, please chime in.
Check with instructions on red Loctite I think you need to heat bolt up with a torch to break the red stuff loose.
Bow-Tie Guy
Yeah, I see where others have tried that. Am a little paranoid wrt heat as far as damage to cam bearing, etc. Looking at the one bolt that I did get out, the only hint of color on threads I can see is light blue, which matches pictures I have seen on internet of new bolts. The 2 end threads being somewhat smeared makes me think perhaps the bolts were a bit too long.
Good luck with heat. Aluminum is a great heat sink, and there is a lot of it.....
I feel your pain, Less. I've been down this road. You need to get the plate pulled over the screws. Then you can get some vise grips onto a few threads. Obviously, that means you need to whittle down the screw head. I used an few drill bits to do that. Start with a bit just large enough to center a pilot hole, in case you need to use an extractor. Drill about half an inch. Then go to a larger bit. Large enough to have enough taper to remove the tapered portion of the screw head. Once you remove just enough, you will be able to pry the cover over the screws. Once off, you should have enough of the screw left to get a small set of vise grips onto it. And if that doesn't work, try an extractor. If that doesn't work, use progressively larger bits to remove the screws, being mindful of the block threads. Don't go any larger than necessary. More often than not, as you start removing the center of a fastener, tension is released and the outer circumference of the fastener will come right out without much effort. The trick is to start out with a small and accurately centered pilot. Then be slow and patient, and don't get angry. You will most likely destroy the plate, but they're cheap. Don't mar the block when prying either. Be gentle.
Les-10 (02-14-2018)
Bow-Tie Guy
Got It Done!
Ended up having to cut retainer plate at the bolt ears with a dremel cut-off blade. Once ears were cut off, pressure was relieved from countersunk bolt heads & was able to use a chisel & hammer to turn them counter-clockwise & out. The bolts absolutely would not budge before. Now having to deal with making sure no shavings got where they shouldn't be. Don't want to ever have this experience again. Won't be forgetting this one for sure!!!
Bow-Tie Guy
It is my understanding that the older version is extinct & can not be sourced period. At least that's all I've read on it. Possible foul btwn bolt heads & cam sprocket??
Bow-Tie Guy
I mocked it up by placing the removed cam sprocket against the cam retainer plate. There was a 5/16" gap, plenty of space for a cap screw head. I don't get it. No way would there be a foul btwn the bolt head and cam sprocket.
I went ahead and ordered the cam kit from AHP which I believe it comes the ARP bolts for the retainer plate (I believe they are not trox). Far down the road (hopefully) when I check on the cam hopefully they won't be seized. AHP said they recommend applying blue Loctite to those bolts upon assembly.
Bow-Tie Guy
Bow-Tie Guy
Supporting Vendor
Received 1,012 Likes
We use the countersunk plates with our own countersunk bolts. They are countersunk Allen bolts not Torques like the Factory bolts.
We do not like the factory counter sunk cam retainer plate bolts. The factory bolts often jam and are a real pain to get out.
We have never had a single issue removing the countersunk Allen bolts that we supply with our kits even with blue lock tight applied to them. If there was a better bolt we would use it.
As long as you use our cam plate with our countersunk cam plate bolts torqued to 11ft/lbs w/blue lock tight your good to go and will be in the future if you even want to swap cams without any issues.
We always sell the plate with new hardware as opposed to two separate items.
https://www.americanheritageperformance.com/
The following 3 users liked this post by American Heritage:
Are you getting your heads back soon? I have about one month to go, I am hoping I can get the cam and cam kit before the heads so I cam start assembling things slowly
Bow-Tie Guy
Great to hear Les Thanks for confirming about the countersunk plate. I've been thinking about it in the back of my mind ever since you had your retainer plate bolts seize. Now I will get a little piece of mind lol.
Supporting Vendor
I know you have already ordered so just send me an email with your info and we will get the cam kit shipped out ahead of the head.
HP@americanheritageperformance.com
http://www.americanheritageperformance.com/
310-326-2399
Les-10 (03-05-2018)
