Key FOB programming to car
Hello,
I just paid my local Chevy Dealer $207.24 for a replacement Key FOB and a GM laser cut coded key replacement for my 2015 C7 A8 Coupe. I still have one of the original working Key Fob and cut key.
Question, I asked the dealer if I could program the new Key Fob to my car when it came in and they said I'd have to bring the car in and pay to pair it to my car. Is this true?
Can I program the new FOB to the car as I have an existing working FOB? Or does the dealer get more money? How do you program it?
Thanks,
Ron
Thanks,
Ron
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
Not true. You can do it yourself. Follow the Long method in this chart. It'll reprogram so you get a 1 & 2 FOB with memory function.
http://forums.corvetteforum.com/c7-g...s-and-rke.html
Long program is steps 1, 2, and then 8 until your done.
Elmer
Elmer
2015 Coupe (02-13-2018)
Received 8,928 Likes
From the 2015 Owner's Manual:
Programming with a Recognized Transmitter: A new transmitter can be programmed to the vehicle when there is one recognized transmitter.
1. The vehicle must be off and both the recognized and new transmitters must be with you.
2. Remove the key base from the recognized RKE transmitter.
3. Place the recognized transmitter in the cupholder.
4. Insert the vehicle key into the key cylinder above the license plate.
5. Open the hatch/trunk.
6. Turn the key five times within 10 seconds.
7. The DIC displays READY FOR REMOTE # 3 or 4, up to 8.
8. Place the new transmitter in the steering column transmitter pocket with the buttons facing up and the base toward the opening facing the passenger side.
9. Press the ENGINE START/ STOP button.
10. The DIC displays READY FOR REMOTE # 4 or 5, up to 8.
11. Press K on each newly programmed transmitter to complete the process.
12. To program additional transmitters, repeat Steps 8– 11. Press and hold the ENGINE START/STOP button for 12 seconds if programming is complete. Return the key base back into the RKE transmitter.
Programming without a Recognized Transmitter: If there are no currently recognized transmitters available, follow this procedure to program up to eight transmitters. This feature is not available in Canada. This procedure will take approximately 30 minutes to complete. The vehicle must be off and all transmitters to be programmed must be present.
2. Remove the key from the transmitter and insert the vehicle key into the key cylinder above the license plate.
3. 3. Open the hatch/trunk.
4. Turn the key five times within 10 seconds. The DIC message displays REMOTE LEARN PENDING PLEASE WAIT.
5. Return key base back into the RKE transmitter.
6. Wait for 10 minutes until the DIC displays PRESS ENGINE START BUTTON TO LEARN, then press the ENGINE START/ STOP button. The DIC reads REMOTE LEARN PENDING, PLEASE WAIT.
7. Repeat Step 6 two additional times. After the third time all previously known transmitters will no longer work with the vehicle. Remaining transmitters can be relearned during the next steps. The DIC display should now show READY FOR REMOTE #1.
9. Press the ENGINE START/ STOP button. When the transmitter is learned, the DIC display will show that it is ready to program the new transmitter.
10. Remove the transmitter from the transmitter pocket and press Q or K on the transmitter. To program additional transmitters, repeat Steps 9– 10. When all additional transmitters are programmed, press and hold the ENGINE START/STOP button for approximately 12 seconds to exit programming mode.
Bill
Bill
The following 2 users liked this post by Bill Dearborn:
2015 Coupe (02-13-2018),
JorgeAM (03-05-2023)
Questions
Bill, Sorry but need a bit of clarification. I don't want to do this wrong.
1. On the "programming without a RKE" option, I assume I would use this to relearn my existing RKE as #1 and the new one as #2 correct?
2. What happens in step #6 to complete the step so you can repeat 2 more times? Is it a the second press of the engine start/stop button?
3. When placing the RKE in the steering column, it is buttons up, and the chrome key portion of the RKE out toward the passenger side? Or is the "base" the other end of the RKE?
4. What is press Q or K on the transmitter/RKE?
5. On step 10, do you repeat steps 8-10 instead of 9-10. I assume you would place the second RKE in the steering column? Or does it just need to be near?
Thanks,
Ron
Thanks,
Ron
Bill
Bill
Thanks,
Ron
Thanks,
Ron
short adds 3-8
2) The three button pushes clear the recorded information on the FOBs and it is then ready to learn new FOB information 1-8
3) Buttons up, key ring slot toward passenger door
4) When someone copies directly from the Owner's Manual, there are pictures or symbols in the PDF. They don't show up as pictures when copied and turn into a letter. "Q" is a picture of a lock and "K" is a picture of an open lock.
5) You press the start/stop button for the process to recognize the next FOB. When you are done programming, hold the start/stop button in for 12 seconds to exit the programming session.
Elmer
I complete 8 but 9 never comes? The DIC never displays that its ready for the new transmitter.
when i insert the fob into the column how long do i have to wait till it is ready? It is extremely fustrating.
If you are doing the long program, the first rule that you should follow is the one in RED that says NO FOB ANYWHERE near the car.
SO, what is your problem and we can proceed from there.
Elmer
Well, since you are coming in with a new situation and adding it to an old thread, I really don't know what you are trying to do.
Elmer
Elmer
I am doing the long program. Lost both trasnmitters. What do you mean no fob anywhere near the car?
Elmer
You've lost BOTH FOB devices? Do you have the key for the FOB? Normally, to do the long program, you would remove the key from the FOB and then place the FOBs 10' or more away from the car and then insert the key into the trunk key slot location and begin the 5 quick turns of the key to start the programming. If you have the FOB in your hand or pants pocket, the car will sense it and it will cause difficulty doing the long program.
Elmer
Elmer
Okay this is interesting. So this is what i did.
i purchased an old fob from a member on this forum and it is a auto coupe.
I did the 5 key turn and followed the steps all the way to 9 with the transmitter IN the car.
It says learning keyfob pending and so forth.
I get to step number 8 where i put the fob into the column and press engine start. Thats where nothing changes after that.
are you saying because i had the fob with me in the car, it is being improperly programmed?
At step 9, you briefly push the engine start button and get this action DIC will say to wait 10 minutes and will start counting down the minutes. Did you get the message and the start of the 10 minute countdown?
Also, did you notice AND pay attention to the really big red letters in step 8? NOTE: Make sure NO old remote transmitters are anywhere near the car. THIS IS IMPORTANT!
NOTE: It is recommended that you test the Steering Column slot for functionality before going past this step. If the SC doesn’t function, you will be on a tow truck to the dealer to get your remotes programmed.
Elmer
Elmer
Elmer
Elmer
On the side note there is no warnings from the owner manual
Oh my word.....
Lets get on the same page, shall we?
Please open this link!!!! It is in post #2 http://www.ls2.com/boggs/c7/C7RKEProgramming.pdf
This is why a new thread should be started on a new problem.
Elmer
Elmer
Do not have any transmitters in, on, around, or close to the car. Close is inside of 10'. Around is within 10'. In and On are self explanatory.
Then take it from the top and give it a whirl. By that I mean stop the process. Start it over. Have only the key near the car.
When you put the FOB in the slot, place your finger on the end of the FOB and push and hold it lightly into the slot.
The instructions work. Many people have read, followed and successfully programmed FOBs anew as FOB 1 & 2. The instructions must be followed to the letter. That's why there is all the RED stuff on the link.
Elmer
Elmer
Elmer
Elmer
Thank you for taking your time to respond.
No problem. If the instructions are followed AND, this is really important, you must have the correct part number for FOB that goes with your car. All this work is moot if you don't have the correct FOB.
Elmer
Elmer
Figured it out...on long program anyway you have to have the FOB at least 10 feet away from the car to get the message that car is ready to learn to appear. Finally looked up more info on this forum after failing to figure it out for 20 minutes.
When I said the FOBs must not be close to the car, I meant NOT close to the car. That sucker is sensitive!
From my instructions:
Elmer
Elmer
