Replacing front fender liners
Hello
I figured I'd post it here instead of the C5 section, if it needs to be moved, please go ahead.
Looking for information on replacing damaged front fender liners for a race car build.
The car I'm looking at needs new fender liners on both sides, and they are bonded in from the factory.
Looks like a major job - or is it?
If anyone has replaced them, please chime in!
DK
DK
I replaced the passenger liner in my car after hitting a cold cone at higher speed at an autocross. Its a time consuming job but not super difficult. Old one has to be chiseled off the frame. Leave some pieces of the adhesive behind so you know how far off the frame pieces to space the new one. Clamp in place and fit up the headlight and fender and check gaps before you bond the new one in place. Then use the adjustment on the fender and headlight covers to get the gaps back to normal.
D K (02-14-2018)
heat gut will break down the adhesive, but replacements can be expensive. If you buy used, make sure they were removed properly. It really easier to just add a few fresh layers of fiberglass than to replace them, just take off the fenders and lay a few new layers one top. You'll likely end up with some "self clearancing" eventually
I've replaced one in my garage. Same technique as v10climber mentions - chiseled off the old adhesive (its about 1/8 in thick), leaving behind a few bits to aid in spacing and alignment. Getting the new liner lined up exactly is difficult but I managed to do it.
My car has accident damage where the nose went under a truck and the weight took out all brackets and braces that were connected to the frame rails.
So headlight mounts, hood mounts ecu (pcm) mounts, anything besides the main longitudinal frame rail is gone.
Hello
DK
DK
The inner fenderwells are expensive (used) and tricky to install. I ended up attaching the fender to the inner fender and then mocked up and drilled a few pilot holes as markers for the proper fitment.
I then removed the fender and installed the inner fender using said
alignment holes with screws to hold everything in place until the adhesive dried. When it's all set up just remove the screws and fill the holes.
I bought the inner fenders from Contemporary Corvette in PA....it's very important that someone knows how to remove them without damage. They also sell frame sections as I needed a new header bar as well.
The 3M adhesive is expensive but the special gut to fit the cartridge is
around $400.00 I borrowed one from a local bodyshop.
D K (02-19-2018)
Lord Fusor is what was recommended in a few places on Corvette Forums and what I bought/used. The gun to dispense it wasn't that expensive. Like $45 off ebay if I remember correctly.
