Anyone use KW shocks?
Thought I would look into double adjustable shocks for my C5Z. I have the DRM Bilsteins which are better than OEM but not a lot. I have used Koni SA shocks on different cars in the past and liked them but found the quality may have dropped somewhat. I would like to have the rear rebound fairly firm but compression fairly soft which you can't do with an SA shock.
Seems the KW Variant 3 can be bought without coil overs but I don't have a clue where the adjusters are or more importantly, how accessable they are.
OP, you could have a set of Bilstein's revalved several times to get what you wanted for the cost of any of the more expensive options. Hell, you could probably even get them converted to adjustables for less than most options.
chandretti15 (12-28-2019)
Thanks for the comments about KW. Have to admit I don't know anything about them. I thought all shocks would have a steel body.
Penske shocks are almost twice the price and only seem to come set up for coil over which I definitely do not want.
I am not convinced that the DRM revalved off the shelf Bilsteins are that much better than the stock C5Z shocks so not sure that revalving them again is going to be all that great. As for changing a non adjustable shock in to an adjustable one, I would have thought that would be a much bigger job.
So how happy are you guys who use Koni SA shocks? I will get some of the adjustability I want by leaving the rears moderately soft and the fronts stiffer. Don't like where the adjusters are but I suppose I could live with it although I would think you need to keep them covered with tape or something to prevent all sorts of grit getting in to them.
With Bilstein's, it's just a change in piston rod. Other shocks are more involved (especially if the adjuster is in a remote reservoir or something like that), but it's simple for a Bilstein monotube, which is why I suggested it.
Tomswheels (02-19-2018)
The nice thing about a DA (like JRZ or others) is you get to find you preferred setting with adjusters, but also the gas charge. About the only thing that needs disassembly is the hi speed release. (that's for sharp quick release, like apex curbs)
They can be credit card busters though. But can last forever.
Mark.
Mark.
Even SA shocks like the Konis allow me to change settings somewhat depending on track, tire choice and weather conditions. Fixed valve shocks don't allow this type of change. Just wish they were easier to adjust.
Or get some MCS doubles from Sam.
Why buy MCS doubles from Sam, when he won't even run them on his own car? He's gone back to Konis on his car(s) after testing the MCSs. Seems counterproductive to typical CF advice, but if less ***** are faster (or as fast) at a significantly lower cost, then you should use less *****.
I'd use Whitener for Bilstein builds in a heartbeat.
