DIY directions for cam installl. Paging AHP!! 116
Looking for directions for cam change without removing heads or intake.
I already have correct springs installed from Khole. Thank you!
if if you would like some instant help you can text me at+19254347099 I’ve done cam swaps about 4 times on these ls7s and have a pretty good grasp on what I’m doing
hotrod03 (02-18-2018)
1/4 mile/AutoX
1/4 mile/AutoX
in the process of installing same cam !!!! looking forward to the finished project !!! (headers,Vararam,coilovers,new brakes,seats,harness bar,etc.) it never ends !!!!!!!
The area I am unclear on is how to actually get the cam out. I've read of people dropping the subframe and doing all kinds of wild things. How do you actually do it?
pull the rack towards passanger side after unbolting it, to remove the harmonic balancer with a pulley kit then pull the cover then take off the cam sprocket and timing chain then cam plate cover then take the cam out. Make sure the lifters don’t fall in side when it’s out or your totally F*****.
Pounder (02-18-2018)
1/4 mile/AutoX
