FS: Performance Lower Shifter Boxes
Supporting Vendor
Performance Shifters and Shifter Boxes
We replace the worn torque tube and shaft bushings for a tighter, smoother shift than factory. Use with your factory shifter or any aftermarket shifter for the tight smooth shift you want that won't wear out.
Lifetime Warranty
Delrin Torque Tube Bushings are stiffer than polyurethane or factory rubber but dampen vibration and road noise better than solid mounting.
Factory shaft is reconditioned, bushings are replaced with #SKF Needle Bearings and seals for a smooth shift that will never deteriorate.
Aditional seals added to keep debris out.
I rebuilt my first shifter box on my C5 about four years ago, (at about 80k) the car has almost 200K on it now. I did my C6 about 30K miles ago and I've done four other C6's as well. I've seen terrible looking bushings in cars with as little as 40K miles on them and I'm confident enough with the turn out that I'm happy to guarantee my work for the life of the car, no matter what.
Fastest Reply for Orders and Inquiries
Tmodcustoms@gmail.com
__________________
TMODCUSTOMS Specialty CNC Products
C5, C6 & C7
Performance Shifter Boxes
Upgraded Shifter Options
Zero-Slop Shifter Linkages
Don't replace your clutch without upgrading your linkage!
www.TMODCUSTOMS.com
info@tmodcustoms.com
C5, C6 & C7
www.TMODCUSTOMS.com
peterskunk (09-17-2018)
Supporting Vendor
Here's a quick video covering the modifications to the shifter box.
Here is your typical shifter box, with 30.000 miles on it.
And some additional pics. Please feel free to ask questions, Shoot me an email or a PM. Thanks
Chrisbequick (04-01-2021)
Supporting Vendor
I'm sorry I forgot to add pricing info. The rebuilt box is $160.00 shipped, I use USPS Priority 2 Day shipping. There is a $100.00 core charge. If you send you box in I can have it rebuilt and back in the mail in a day or two.
The following 2 users liked this post by TMODcustoms:
Lango (02-14-2021),
rfrancisco (08-14-2020)
Thanks for becoming a new vendor. I’m very interested in what you have to offer.
TMODcustoms (02-18-2018)
Supporting Vendor
Thanks, happy to be here! I've been on this forum for a long time but new to being a vendor, still have to get my signature figured out haha. Shoot me a message if you want and I'll get you taken care of.
Supporting Vendor
No it's not just a kit. I take the factory box and machine away the existing bushings around the shaft and mill a larger pocket to press bearings and seals into. After that the factory plastic end cap is replaced with one I machine from billet aluminum and made to house bearing\seal, not just a bushing.
You can however just pay the $100.00 core charge, I'll send you one and you can send me your core when you pull it out, I'll refund the core charge as soon as I receive your core in the mail.
Interested in how this compares to the lower that comes with the MGW shifters?? I already have a 10 year old MGW and don't know if I want to swing $400 for a whole new shifter to get the benefits of the new lower.
Supporting Vendor
If you have a stock shifter, an MGW , B&M, Hurst, or any other shifter that only includes the top section than you'll definitely benifit from my lower box. If you have an MGW shifter that includes their lower box then your good to go, the difference between MGW's lower box and mine are negligible if anything. Both lower boxes address the same shortfalls of the factory box.
nullpointer (02-18-2018),
VFR RC46 (01-31-2019)
Supporting Vendor
It sure will. Stock shifters developed slop very quickly, even cars with as low as 20k miles on them generally have a large amount of slop . This slop is caused by the torque tube bushings as well as the bushings the shifter main shaft rides on. My box upgrade will not only eliminate the slop that builds up over time from day one, it will keep your shifter slop free and tight, for the life of the car.
Shoot me an email, I'm happy to answer in more detail.
TMODcustoms (03-05-2018)
NCM Lifetime Member
Received 3,929 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
