[C2] BA9's Dash Flutter
Old 02-18-2018, 10:09 AM
woodsdesign
woodsdesign's Avatar
Default BA9's Dash Flutter
I replaced my dash bulbs with LED BA9's about a year ago. I love the way they light up the instrument cluster. However, I noticed a flutter when I was on a rough road. I thought one or two of the sockets were loose in the holes but when I checked it out I found that some of the bulbs were loose in the sockets . Now I suspect that that is the reason for the flutter.
Has anyone else experienced this? Anybody have an idea of how I could tighten them. Maybe foil??. It is an Electric Limited harness. So maybe it is a case of two aftermarket items causing the issue.
Old 02-18-2018, 10:22 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
I don't know what's on the bottom of the LED dash bulbs...if its the typical contact solder 'bulb' contact -- like parking and tail lights, you can heat them up and add solder to the 'bulb' for a better connection and tighter fit. If you add too much its very soft and you can file the 'bulb' down with a jeweler's file quite easily...
Old 02-18-2018, 12:13 PM
woodsdesign
I did try the soldering. It did not work well. I was concerned that the bulb would overheat from the iron. It appears that the side **** are a little smaller.
Old 02-18-2018, 12:23 PM
Frankie the Fink
Army
Small **** are always a problem.
Old 02-18-2018, 12:36 PM
Bluestripe67
Support Corvetteforum!
Bluestripe67's Avatar
Received 2,125 Likes on 1,464 Posts
Old 02-18-2018, 12:50 PM
426 Hemi
426 Hemi's Avatar
Can you stretch the spring in the socket?
Old 02-18-2018, 05:23 PM
SoCalErv
SoCalErv's Avatar
Army
Very concerned with this post as I am finishing the cluster restoration and have used the same LED's. I was concerned with a few of them not securely fitting in the sockets.
I will be monitoring this post before I reinstall the cluster.
Old 02-18-2018, 05:40 PM
Frankie the Fink
Army
Well - I hate to even mention bubble gum wrappers or tin foil wrapped around the bulb sockets... The dash bulbs have one contact on the bottom...even if the prongs are a bit loose there should be enough socket spring pressure to make contact. Are you completely sure you're dash headlight switch rheostat is clean and uncorroded ?
I'm just sayin'
Old 02-19-2018, 04:17 AM
babbah
babbah's Avatar
Old 02-19-2018, 07:46 AM
woodsdesign
I'm just sayin'
I installed a new HL switch last year. I will investigate stretching the spring but I think it is the damn little tit thing. Like the other guys mentioned little **** are a big problem.
To BA9's Dash Flutter
Quick Reply: [C2] BA9's Dash Flutter
