Horn Issues
Horn Issues
As you see from the pic the plastic tube where the spring and contact pin is gone. Yep, I broke the top half that the retainer turns into.
Is there a replacement for that plastic tube or is it a part of another part that you get to by pulling the wheel.
Received 3,138 Likes
If you're talking about the hole there at about the 7oclock spot there is a plastic retainer that goes in from the front to hold the pin.
Any of the corvette places (maybe even NAPA) will have the whole kit
if it's something else you're referring to....then I don't know the answer
HIH
M
HIH
M
This is what you need IF you broke the white plastic tube.
https://willcoxcorvette.com/corvette...-contact-69-82
DUB
DUB
Thanks for the info. I have the lower contact part ordered. When I replace that will I need to check lower in the collum or should the horn function?
It is possible that the plastic cover that goes over the U clip can be old and break easily.
IF it breaks...your horn will blow continuously until it either drains the battery or melts the horn relay due to excessive heat in it. AND...it can also heat up and damage the sporing in the upper contact in the photo below
Here is a link the the plastic part I was talking about.
https://willcoxcorvette.com/corvette...-fingers-70-89
DUB
DUB
If you take a wire and touch the brass portion of that lower horn contact and put it to a good ground point...you horn should blow.
DUB
