App for more than the engine/pollution control?
Is there one for obd2 in general (AN APP for a smart phone) that you guys know of ? Or suggestion on a much less expensive tool than the Tech 2? Thanks.
Link me up if it's already settled in another thread.
I have a Bludriver dongle for clearing codes and scanning, and I use a GoPoint for laptimer integration. Of course HPTuners makes a great general purpose OBD2 scanner for clearing codes and resetting crank timing etc
I use Torque Pro for checking and clearing codes as well as watching sensors. Understand that you'll need a decent bluetooth dongle to plug into your ODB port.
I have torque (free ver.) and I believe it's just engine & emissions .
Thanks.
I don't think it will do any GM specific modules/codes. I don't know if there are any tools short of a Tech2 that will do what you're after.
Plotting short term fuel trims and such is handy to help find mis-fires,
vacuum leaks and etc.
Good luck!
Tim
Froggy, I think the Torque App is your best bet. I use the "Pro" version. There are "extended GM and Ford" PIDs available, but even those are still engine and drive-train related. (I can get the trans temp on my C5Z) No BCM functions are there. If you upgrade to the "Pro"version, also download this plug-in: https://play.google.com/store/apps/d...owl.torquescan
Good luck!
Tim
Good luck!
Tim
You can try the EASE OBD2 software personal package. As I recall you load it to your PC and uses an ELM327 into the port. It looks like $140 for everything but the air bags (pre-OBD2 for C5 corvette). I had the original software/hard wire package 15 yrs ago and it read PCM and bi-directional for the ABS bleeding.
http://www.scantoolsoftware.com/gm-scan-tool.html
annoying video, but this guy found a Tech 2 simulator. I haven't used it, but it would do the trick.
https://www.youtube.com/watch?v=BxYW6lB1uNw
