Help needed: Removing winglets from Stage 2 front splitter
Has anyone ever removed the winglets from their Stage 2 splitter or anyone know how to? I tried to take them off by unscrewing the 2 bolts like I did for removing my Stage 2/3 rear wing but it just kept twisting/spinning and won’t come off. Am I missing something? I should be able to just take those bolts out and pry at the double side tape. Any help would be greatly appreciated Thanks!
https://www.corvetteforum.com/forums...-thread-2.html
Check out the last 2 posts I posted. Stage 2 front winglets should be just the 2 bolts on the sides.
I haven't put my stage 3s on yet. However I remember someone saying there are a couple screws that are vertical through the splitter with nuts on the inside. That may be your issue.
Yup, gotta get a wrench behind there because there are nuts on the back that need to be held while you turn the bolts. If you are going to put the stage 3 winglets on you should also use a hex head bolt for the bolt towards the front of the vehicle otherwise it will be VERY difficult to tighten it down with a torx.
Received 8,928 Likes
You do need to get to the nuts on the back that aren't shown in this picture. On my car getting to the nuts required removing the side air dam (shown in picture behind rear bolt), loosening the front under tray and pulling it down to gain access to the nuts.
Bill
Bill
I somehow managed to do it without doing that but it was a huge pain in the *** and took a lot longer. LoL
I have a Grand Sport with the OEM GM exposed carbon fiber ground effects package. I'm looking to take off the Stage 2 "wimpy" looking winglets and install the Stage 3 canards / winglets on my front splitter. I want carbon fiber replacements for the OEM Stage 3 plastic ones and I see that these are made by Anderson Composites, C7 Carbon and soon as I understand it, APR. Has anyone bought any of these any installed them? They all look the same and are very similar costs but I'm not sure if one is better than the other? They all seem to have a 6-8 week wait for them!
