possible to remove the power steering pump bracket from power pump
Oil Producer
without removing the pulley on a 1986?
its the last accessory bracket i need to clean up and id like to unbolt the bracket from the pump, clean, put back.
I dip all my coated brackets in ild gasoline for a few days then the grime comes off easy with minor scrubbing.
Yes. The 3 bolts are hard to access and may turn only a small amount each time by flipping the open end wrench. I have seen someone drill a hole in the bracket tinaccess one of the bolts.
Oil Producer
gents are you talking about a genaric kit or is there a specific kit in mind?
this one locally available to me.
https://www.princessauto.com/en/deta...et/A-p2990177e
I didn't realize my "hole drilling operation" would be worth $50! Once you get the pump off the slow way, drilling the hole in the pulley is easy. That makes the re-installation and any subsequent removals easy.
Bfenty (02-21-2018)
Your local Autozone will rent these to you at no cost. You essentially buy the component as the rental fee and they credit your card in full when you return.
I've done this many times for quite a number of tools. Actually simpler than drilling the hole in my opinion.
Good Luck
Good Luck
