Right e85 set up for 600 rwhp?
So i have been reading e85 posts all morning. I been thru 15 pages , and still havent had my question answered. My current setup = ecs blower kit, headers, , 60lb injec,bap and meth. I put down 610 thru an a6. I'm looking to switch to e85 , I'm also fine with the 610rwhp i make now. What injectors could i pass for the conversion and will i need aftermarket fuel pump or will the bap suffice?
ID 1050x or 1300s. ECS fuel kit or if you want to go all out and drop tanks the fore setup.
DOUG @ ECS (02-20-2018)
What unreal said. Stock pump could last a weekend or a couple years on e85. If you’re happy where you’re at I’d leave it. I’m at a higher power level but I’ve dropped 5K ish into the fuel system. You might be able to squeak by on id850X but I’d go id1050x if you do.
Received 1,193 Likes
St. Jude Donor '15
Fuel system is the last place to try to save money. The ECS kit is a bargain. Much cheaper than a fragged motor.
St. Jude Donor '15
Mind blown
i think it takes more energy to ask on a post first, then shorty after reply to a PM then shortly after go to the website and purchase the item I’m thinking it’s the opposite of laziness.
