JACKED up my Vette! C7 lifting tools and technique
Using the correct method to jack up a C5, 6 or 7th generation Corvette is very important for safety and to prevent damage to the vehicle. I posted a video on my YouTube channel explaining the importance, technique and tool that I use for lifting my Grand Sport. I hope it helps people out. If you have any mechanical requests or car jacking stories please leave them in the comments. Thanks for watching and be safe! -Glen
The following 5 users liked this post by Ozzstar:
cdnrx1 (02-20-2018),
JDub64 (02-20-2018),
Johnp94 (02-20-2018),
KGrant (02-21-2018),
Scoobydoobydoo (02-20-2018)
Just wanted to say thank you for the great videos. I've been looking at the Reverse Logic pucks for my new Grand Sport for a while so that when I go to the dealer to get my oil changed that I will have them and not get my side skirts damaged, I've read that the regular height ones (without the added spacer) are fine for getting by the side skirts but seeing how much room you had with the ones you have is really worth its weight in gold. It's nice for me personally to be able to see in action what may appear to others to be straight forward information to help alleviate any concerns that I have. Forewarned is forearmed as they say. It also helps me focus in on what product will work well when there are TONS of options out there to choose from. Thank you again and keep up the great work!
I do something similar except I lift the car from front center first. Using hockey pucks, a few 2 x 4's, and cement blocks placed at the side jacking points. Then I do the same at the rear. I do not trust jack stands. When I do use them I place cement blocks with 2 x 4's under the car as back ups.
The photo shows the car with all 4 wheels removed. I painted the wheel barrels gloss black.
bankers1 (02-22-2018)
Great Idea. I did not think of painting the Barrels. I'm doing my Calipers in a coupe weeks (above 60* out) and I'll do it at the same time.
I don't trust jacks stands either, I put some 8X8 PT lumber under X members so at least I have 8" to survive......
