07 Z06 Diff Fluid Question
Hi all, I recently tried ordering diff fluid and the diff cooler clip for my 07Z based on numbers from this thread:
https://www.corvetteforum.com/forums...-specific.html
The dealer told me that the I need the fluid and friction modifier and also mentioned that the clip PN did not cross reference to my vin number.
So my questions are:
1. Do I need the friction modifier with the fluid? The dealer said that they add the modifier with the fluid in their service department.
2. Should I ignore his advice and order the clip listed? Do all Z06 cars use the same cooler clip?
The part # for the clip is 24205103
If you PM me your address, I will mail you a clip. (Sold my Z)
I always got a spare, as they are easy to lose..
GM diff fluid is fine...friction modifier is already in it. I recommend Amsoil 75W-90 Severe Gear Lube, which also doesn't require the additive.
GM specifically says not to add more friction modifier to their OEM dif fluid.
