Worried
Worried
It, 71 outside today in canton and I decided to take her out for a spin, but she idles a little rough. I rough but after twenty minutes she's still has a miss. Am I being to conservative, it's been in storage since October. .any ideas
Settle down.. dont throw a rod.. hahaha lil joke.
A miss can be described as many things. Does it only happen at idle? Did your battery die? If so it may take your computer a little time to figure things out. Could be rich. Do you smell gas from exhaust? Any black smoke when you rev or idle?
Usually a minor issue will be masked with some throttle.. an idle is a tell tale of the condition of a motor.
This could be bad fuel.. did you treat the fuel?
Thanks for responding, the battery never discharge all winter I started it every 3 to 4 weeks and I treated the gas with Lucas and stabilizer. I also filled it up with 91 octane before putting it up.
If it continues, I have a scanner that we could try reading what is going on. If you drive over to St Rt 21 and go north, I live just on the other side of I-76.
With that said, if you didn't fill the tank all the way to the top, and depending on the day you last put gas in, you could have some condensation in the tank. Run some fuel injector cleaner and some water remover and see if the issue goes away.
We have had some pretty rapid warmups lately, with a lot of rain. Our cars are experiencing condensation. I had to put a dehumidifier out in the garage today. You simply could have some moisture in the electrical connections etc making it run rough.
Do you have a timing light to see of all plug wires are firing ? But as I said, we have had such a rapid warm up with rain, the condensation built up all over our cars. I took a gallon or so of water out of the air in the garage in just a few hours.
After everything dries out, it might go away. If it doesn't then I would start to do some checking.
Zen Vet Master Level VII
Thank you for your responses, drcook I live right off rt 30 so I'll be in touch if the fuel conditioner doesn't work
Put 50 miles on her and vary the RPM (that's polite for "Punch It!") and report back.
I'll bet you are good. Our cars like to run--- often.
Looks like I'll need to wait a few days since it's going to rain for a while.I thought is could be a moisture issue, but just wanted other opinions .thanks I'll let you know the out come
Received 3,043 Likes
St. Jude Donor '05
do you have a fuel pressure gauge you can screw on your shrader valve? Its on your fuel rail. That would be a start
How old are your injectors?
Todays gas is crappy...had 2 yr old gas that would not ignite period
