[C2] Spax Shock Absorbers Made a Big Difference
St. Jude Donor '09 & '11
Installed Spax shocks on my 65 Convertible this week and was amazed at the difference in ride and handling quality! After testing a few different settings, it sticks in the corners much better and corners much flatter than previously. I was running Koni shocks and didn't expect such a significant difference. I ended up adjusting front and rear shocks at 20 and 20. My only complaint is that I had to drop the front shocks to gain access to the adjuster ****. The rear adjusters are readily accessible. Expensive, but well worth it!
I'm getting RideTech single adjustables tomorrow. Looking forward to seeing how they feel.
Rick
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
That is nice. I'm curious about any other changes as well.
The suspension is stock other than the Spax shocks. Other changes include BFG T/A's P245/60R15 on the rear, P235 up front, Torq-Thrust II 7 1/2" wheels and Steeroid rack and pinion PS.
I did mount the front shocks 180, but I have a drive on lift and it is easier to just drop the shock and adjust turn the adjuster.
Received 1,974 Likes
I have Spax on my Cosworth Vega, and can't access the front adjustment at normal ride height due to spring interference, but if I jack it up a couple of inches I can access.
I've been recommending Spax shocks here for years. Tires and shocks are the best two "suspension upgrades" you can do, and once you get them dialed in for your road conditions and driving style they make a HUGE difference compared to any off-the-shelf non-adjustable shock, but very few guys ever listened.
Tell us where you bought them, how long they took to be delivered, price, and PART NUMBERS. Maybe others will start getting the message.
Duke
Duke
Duke
Duke
part numbers and where you got them would be good.
thanks
It was a special group order from the Cosworth Vega Owner's Assc. 20 years ago for about a dozen sets through Hutton Motor Engineering in Tennessee, which has been a CV specialist since the cars were new. I probably have a receipt somewhere with part numbers, but it would take me a while to find.
I don't know if they list H-body shocks in their online catalog, but you can check, and contact Hutton to see if they might be available on a special order basis.
Duke
Duke
Duke
Duke
Amazon has them for the 67-69 Camero for $110 front or back, don't know part # or if they fit C2 vette
I just looked up both 68 Camero and 65 Corvette on the Monroe web site and they call for two different part numbers so I would say no. However upon further investigation when visiting Amazon about these shocks it says they are sold by JRP Inc. and when you click on that info you get their phone number 1-905-822-7223. Some times you have to be a private detective (not really, just look around a little.) Let us know what you find out.
I just received the RideTech shocks this afternoon. Unfortunately, they don't provide the mounting bolts for the front shocks that attach the "T" bar to the lower A arm... kind of a let down. The RideTech shock T bar is much thicker than the OEM so the original bolts won't fit. I called RideTech and they said they'd send new bolts, but you would think at this price point those would be included.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
I wonder if they'd change anything on a C1?......or if they make then for the old cars?
What kind of warranty comes with them?
I have same Spax on my 64 all standard coupe since some months, as a replacement for the almost new OEM delco shocks. They indeed giving great car feel very much in line with my cruising driving style. I can easily acces the dials , including on the front shocks where my rather big fingers manage to get through the coils.
One problem I had though was that the rears are about 1" (iirc) shorter than the originals when fully extended. So when mounting they bottomed out the wheel drop too soon in my opinion , compression side had more headroom than standard. I fabricated/welded frame extensions to make them set closer to midpoint.
FYI: I exchanged the standard 196lbs rated leaf spring with a 140/196lbs one (both from Eaton). The 140 is the rate at low compression, 196 at higher compression. Gives an even smoother ride (I had to toughen up the spax setting a bit)
It's most common on '63s due to the geometry of the cast drive flanges. The later two designs were forged, and their geometry allows a greater angle before grounding occurs.
Duke
Did anyone look at post 11 and check with the Amazon supplier regarding Corvette availability?
when I put on the spax, it was with the stock spring. When I mentioned 'stock' should have mentioned I referred to the suspension system. The 140/195 spring that I put on recently had exactly same drive height, so would have had identical issue
Halfshaft U-joint grounding is a problem at full rebaound, and since the rebound limit is established by shock extension, having a little less may be a good thing. I often wonder if typical OE replacement shocks don't have greater extended length than OE, which may be one source of the grounding problem.
Duke
Duke
These are the specs of the delco's and the spaxes compared
The (new) AC delco originals close 258mm and open 377mm.
The spaxes I got close at 244mm and open 358mm.
Duke
Duke
When I had the trailing arms for my 1978 Corvette rebuilt I sent them to Bairs, along with the diff. Bairs advised me that the stock replacement shocks I was going to use (Monroe’s) were overlength at full extension and would void their warranty as they would allow binding to occur.
