Newbie trying learn!
I have a 99 vette and I notice I have a hose that is connected to something under my driver side headlight, lead back to the firewall but it's plugged off. Any clues??
Thx
Mick
Thx
Mick
Received 19,286 Likes
'20-'21-'22-'23-'24
A pic here might help with an answer.
The air pump is mounted in that area by the left headlight. Maybe the pump doesn't function anymore and someone did a halfassed modification to the system.
Received 3,052 Likes
That the air injection pump.
Yes it's emissions related. It's a pump that injects fresh air into the exhaust stream to help to burn any unburned and partially burned fuel in the exhaust to reduce tailpipe emissions. Also referred to as a smog pump or secondary air pump.
Principle of the secondary air system:
MikeG37 (02-23-2018)
Interestingly, that is the air pump of which I mentioned. In my own car I was having problems with the system setting codes so I had the computer tuned to delete it and removed all the components. My car still passes New Jersey inspection.
