[ZR1] Best Ported Heads For Stage 1.5 Cam
Looking for feedback on selecting the best heads for the ZR1 to work with a smaller cam like a BTR 1.5.
I was going to send my stock heads to WCCH but I am thinking of spending more on a set of good aftermarket heads as they seem to produce about 30 more HP on the CTSV's.
Any suggestions ? Anyone using Frankeinstein ? Thats the way I am leaning. Budget is no more than 5K.
Mast
Frankenstein
Mamo
WCCH AllPro
Mast
Frankenstein
Mamo
WCCH AllPro
Mast
Frankenstein
Mamo
WCCH AllPro
Mast
Frankenstein
Mamo
WCCH AllPro
After seeing on the big numbers from head swaps on the LSA boards Im all in. I just need to pick the setup. Those boys are making big power from ported TFS and Mast castings over the ported stock LS3 heads and these are not max effort builds with huge cams at all.
I would use Mamo Motorsports (MMS) LS3 Heads.
Either AFR about 3-4 Lbs heavier VS TFS, or the TFS.
On the CTSV Owners forum ported stockers make
25-30 HP more depending on boost & cam size.
The MMS LS3s (TFS, before the AFRs came out)
Produced 50+ again depending on boost & cam size.
Area under the curve, throttle response and
Driveability are all improved by more flow through
all lift points despite smaller Ports and better E/I ratios.
I brake for nothing (02-23-2018)
Matt Gower of GP Tuning (LT1Z on the board) has also handled alot of both types of builds (LSA Cadillac and ZR1 Vette) with my ported LS3 heads and always produces big numbers in both platforms even with conservative cam timing. When the budget is there for his customer to roll with aftermarket heads Matt almost always chooses my cylinder heads. If you happen to reside in Northern CA (Bay Area) or even reasonably close, I would certainly entrust him to handle the tune. He has worked on ALOT of ZR1's and would be a natural choice here for tuner if you happen to live in that part of the country
I now offer my MMS 260 program in both castings (TFS and AFR) but would probably recommend the AFR version for boosted applications. Honestly an out of the box head simply can't compare.
They are fully CNC ported and hand finished....include lightweight hollow stem intake valves....PAC springs....Titanium retainers and milled to your specifications. The quality and execution is 2nd to none and it comes in well under your 5K budget (slightly under 4K in fact) fully loaded.
Couple of pics below....feel free to PM or email me and we can discuss this in greater detail
Cheers,
Tony
PS.....Feel free to ring my cell phone as well. If I dont pick up leave your name and number and I will return the call 661-714-1317
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
which if the weight is in the deck is beneficial in Very High Boost
Applications, The TFS for NA or Weight conscious applications,
by the time both have been MAMOFIED there is very little difference
in flow or performance.
I used The MMS (TFS) LS3 Heads in my NA 396"
made 690 at the flywheel with 11.7:1 compression
and a mild 243*/249* LLSR (~237*/243* for HR
equivalent). Extremely pleased with their performance,
You would be also.
