[C2] carb adjustment 427-435
Had my matching # motor rebuilt. Carbs were good on the other motor. Was able to adjust them. New motor is in running decent. I can't get any adjustment . They were rebuilt last year. It's a 427-435HP. Any suggestions or advise how to get an adjustment from the center carb??
Received 6,995 Likes
2015 C2 of Year Finalist
are you adjusting the center carb with the linkage removed that goes to the outer carbs? that is where I would start. also double check the timing and get the engine warm to normal operating temps as well
I pulled the manifold off the other engine with the carbs on it. I replaced it wit the cabs installed. Nothing was touched. Timing is right on.
was it different cams in each motor? same dist used? with the same timing used?
check the float levels, moving the carburetor/intake around may have stirred up dirt or something else interfering with the needle/seat assembly.
