Driveshaft/Torque tube/Rear end issues
Cruising
Alright I've been wondering about this for some time now and I need professional advice and help in the right direction if anyone has ever gone through this. My vette is a 2008 auto with 23k miles and for about a month I've been feeling an odd pulse/vibration on the gas pedal whenever I'm accelerating from 0 to 50 mph. I have long tubes and an x pipe but I know that's not the reason I feel the vibration on the gas pedal because whenever I installed the headers and x pipe I never had that issue until now and that is why I'm certain its either going to be an issue with the driveshaft or torque tube or maybe rear end. I do push my car a bit hard every now and then so maybe that would have to do with that? Another thing I would like to add is that whenever I drive it and come back home as I drive up my driveway and I leave it in D while holding the brakes, I also hear a grinding like sound coming from the rear and when I put it back on park the sound would go away. Well I hope I don't sound crazy but if someone on here can help me out it would be greatly appreciated.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Can't help you but it may be drivetrain related. I do know of a fellow named Victor Sellens (you may have seen/heard his name as he used to be at Corvettes of Houston and 510 Engineering). He's got his own shop now called VZ Autoworks. Maybe give them a shout and ask?
The following 2 users liked this post by AORoads:
BLUEMEANIE (02-24-2018),
Corvette08ls3 (02-24-2018)
Cruising
It's not the brakes I replaced them 3 weeks ago. And I think it might be something else because today as I was pulling up my driveway and I heard it again so I revved it a bit to see if I can hear it better and sure enough it's definitely coming from the rear end. I hope it's just the mufflers going bad since I still have the stock ones and I don't know if they go bad early on if equipped with long tubes and a bigger x pipe.
Cruising
Thank you I will seek them out. Earlier today I heard the noise again and I'm starting to think it might just be the mufflers going bad since mine are still the factory mufflers. I revved it and I heard the noise coming from the rear end and it does sound like a weird rattle whenever the rev goes up and down again. I guess having long tubes and a bigger x pipe wears out the factory mufflers a lot?
