FS: KONI 3013-1023SPORT (Yellow) Adjustable Shocks
$375 Shipped
Koni serves Sporting Drivers with a carefully designed range of sport shock absorbers. This product focuses on exceptional road holding and handling, combined with a reasonable level of driving comfort. They can also be used with spring kits to lower a vehicle up to 35mm.
To adjust the 3013 1023sport shocks you will need a small dowel pin or you can use a small allen key. If you look near the lower mount on the shock you will find a small window which has two or three small holes that you can see inside. Using the dowel pin, or allen key an making sweep from right to left/left to right you can increase or decrease the rebound adjustment setting of the shocks.
To increase the rebound you will make sweeps from right to left. (Towards the + sign)
To decrease the rebound you will make sweeps from left to right. (Towards the – sign).
Shocks have apx 10,000 miles on them.
