WTB: TAC Module 2002 C5
TAC Module 2002 C5
Looking for a 2002 Corvette TAC module, mine is part number 25311783.
Zip is 01463.
No longer needed, found one
Zip is 01463.
https://www.corvetteforum.com/forums...cs-issues.html
Tac module
Check out this recent thread below from the C5 Tech and Perf section. You may have a TPS issue which might save you some money. Worth a look.
I had the crank no start issue and i sold the car as is AFTER replacing the TAC module. Guy who bought it called me an hour later telling me it was a bad PCM ground...
grounds to PCM
I double checked I have a good ground on PIN 1 and 40 both on the blue and red connectors, which I believe are the only grounds for the PCM.
