My 59 won't turn on after put back cluster
All,
I took out my 59 cluster to have the speedometer repaired. Now I put it back in but the car won't turn on. The battery is 100% and the headlight is working. But when tried to turn on the key, even the fuel gauge don't want to work. Someone mentioned to make sure I have good grounding for my cluster. I bolted down the 5 bolts of cluster back into frame. What other grounding do I need to look for? I labeled all my wires and make sure they put back in place. 5 wires connecting to the ignition switch is there. What other grounding wire(s) I need to look for? Car was running before I took out the cluster. Car has new starter.
Is it possible that I can turn the ignition tumbler without the key all the way to the right? is this mean I have a bad tumbler or ignition switch?
Thank you in advance for ideas.
All,
I'd guess loose connection if starting wasn't a problem before. Was the new starter added at the same time as the cluster R&R? I'd start with a test light at the fuse panel then onto the ignition switch.
In case you need one, member popawana offers high quality PDF wiring diagrams for free.
https://www.corvetteforum.com/forums...-diagrams.html
All,
