Wire on alternator
Received 1,244 Likes
What year is your Corvette?
That does not look like the original ground wire.
The alternator picks up its ground from the mounting bolts.
That wire brings a ground from the alternator to the radiator support.
The other end of that wire should connect to the radiator support, it brings a ground to the headlight and horn brackets.
Received 2,878 Likes
Hi B,
It appears the connector and wire tail may have been cut out of the harness to make that ? (don't know what to call it).
You don't say what year your car is... photo shows 80?
Regards,
Alan
Maybe under the clip is the location the connector started it's life?
Regards,
Alan
