. First time owner few teething issues
So I've finally got my C6.
As i expected I've got a few teething issues which I'm hoping you guys can point me right on.
So first and scariest. Driving home finally gave it a bit of welly and horrendous noise. Thought it was a valve but that was just panic. Its an awful belt or pully noise. Wd40 around the crank pulley stopped it for a few seconds so i got some belt dressimg and applied loads and all silence. But im guessing this is temporary. Is the concensus crank pulley, idle tensioner or belts?
Secondly, if I'm in traffic engine is great, however if I start up and get up to speed quickly after about 5 mins the water temp drops to zero and a dic warning about hot engine. An odb reset and all fine again but i think I have a 160 stat, the temp goes up to 160 max without traffic. Btw, it's really cold here right now. Idle is pretty lumpy, as in hot cam lumpy, and it is quicker than I'd hoped.
Finally air bag and heated seat aren't working, trapped wires underneath?
On the positive side I've started going through the options list and it has the z51 option, so going to check the rest.
Thanks for any help.
John 511 (02-24-2018)
Popular Reply
02-24-2018, 01:08 PM
Received 1,675 Likes
Did you purchase from a dealer or private owner?
Some problems you're having could be from several different sources, depending on whether you got the car from a dealer or from a private owner. A dealer would be likely to have fixed some of those.
The following 4 users liked this post by Vette_DD:
Evander Holyfield (02-24-2018),
FortMorganAl (02-25-2018),
Gotta-Qik-C7 (02-24-2018),
Tombovette (02-24-2018)
Didn't you test drive it before you purchased it? It sounds all of these issues would have revealed themselves on a 20-30 minute test drive.
Perhaps you should be asking the seller these questions? I doubt all this just started happening just after you paid for the car and was driving it home. You need to get all the maintenance records from the seller and find out what he changed or modified.
On a good note, you do seem to have gotten what you paid for. Congrats.
Essentially the belt dressing is like a temporary lube and reducing the friction for a short period of time from running untrue probably, as far as where you purchased it from maybe you have some recourse if it was a dealer purchase. 90 day warranty maybe longer ?
The following 7 users liked this post by jrose7004:
Allan (03-04-2018),
ByRiver (02-24-2018),
Landru (02-24-2018),
and 2 others liked this post.
Kimball (02-27-2018)
Received 3,626 Likes
2016 C6 of Year Finalist
If it was a private seller than you can ask the seller what he did to it besides changing the thermostat. He may or may not go in for the repairs. if it was a dealer you might have a warranty but probably not.
Lumpy idle could be normal as the LS2/LS3 have a lump in their idle for muscle car feeling.
I agree on the harmonic balancer.
If seat heater and air bag are both on the same seat then you can at least limit your troubleshooting.
Welcome to the C6 world
Received 1,136 Likes
My LS2 is butter smooth.
my guess is balancer is due. Low coolant due to rad leak slow from the plastic rad caps. That’s my guess....my 2500 dollar answer to the guy asking questions.
oh as for electrical Issues… Could be a fuse, broken wires, flood car, bubblegum, feature of the car doesn’t have with buttons that are just for looks lol
Posted by someone who has done it.
My LS3 idles rough by car standards, same engine in a Denali idled smooth. Corvette's motor is built for max power so it will have a lump in the idle or a shake, whatever you want to call it. And I didn't mean to say it was like a muscle car but you don't see people complaining about how a 60s early 70s V8 idles.
