Got back into the 9s after 8 LONG years - 9.933@136MPH
Supporting Vendor
After 8 very long years (Dec 19, 2009 to be exact) I finally got a car into the 9s again running all motor, and then a second time after hotlapping it.
It was a last minute decision after seeing how cold it was in Sacramento on Friday and that the forecast was for it to be only 3 degrees warmer today. The DA was around -855 ft when we started running at noon and -709ft when I ran my quickest time.
My very first pass was a 10.006 and since it was quickly getting warmer I figured that might have been my one and only shot.
I launched 100RPM higher on the second pass (2300RPM) and was running .023 faster by the 1000ft mark but then the car started getting loose to the point where I was forced to lift at first and then finally tap the brakes to keep it from hitting the wall.
The guy at the track said it was likely because it was still very cold so I waited a bit before running again only to have my next two passes be even worse. I had the car aligned several weeks ago so I'm still not sure if it was from that or the cold track. I'm hoping it was just the track as I've made a couple dozen clean passes since the alignment without issue. The only reason I don't think it might have been from the cold was because there wasn't any wheelspin as it got loose, it just started oscillating back and forth beyond 125MPH.
After waiting a little longer still the car thankfully went arrow straight all the way down resulting in the 9.933 pass. I quickly came back around to see if I could replicate it as well as finding somebody to record the next one. It ran slightly slower but was still a 9 second pass so at least I got something worthwhile on video.
Supporting Vendor
This is a pretty complete front to back list of mods and/or stock equipment:
- RaceStar front skinnies with M&H radial tires
- Vette-Air intake system
- Attack Blue Air filter
- Stock LS7 air intake housing
- Dewitts radiator
- B&M transmission cooler
- Ported, stock LS7 intake manifold
- Stock LS7 injectors
- Stock alternator and water pump
- No front sway bar
- Stock spark plugs and wires
- Stock LS7 heads that have been milled .030 with stainless steel exhaust valves and stock titanium intake valves
- HUGE aftermarket cam from Vette-Air
- PAC 1207x valve springs
- Stock LS7 block
- K1 crank, Mahle 4.130 forged pistons, Callies Ultra H-beam rods
- Mighty Mouse catch can
- Joe Gibbs LS30 engine oil
- Moroso Oil filter
- Fluidampr SFI approved LS3 harmonic balancer
- ARP rod bolts
- ARP crank bolt
- Stock timing chain and gears
- Stock head gaskets
- Stock LS2 oil pan
- LG 1-7/8" headers with the rest of the exhaust removed
- MSD 8733 2-step launch controller
- Cartek line lock kit
- Upgraded 6L80E tranmission with Alto clutch packs
- Yank SS4000 converter
- ZR1 reproduction rims with 315/35/17 Hoosier drag radials
- Stock LS2 fuel pump
- Custom differential brace
- Z06 rear sway bar
- Stock C6 Z06 differential with reinforced upper ears
- Driveshaft Shop Level 2 axles
- 5 point custom built roll cage with driver side swing out bar
- Simpson Racing cam-lock 5 point safety harness
- Removed passenger seat
- Tuned by me with HP Tuners
- QA1 double adjustable shocks on all four corners
- 91 octane mixed with Aces-IV octane booster
Supporting Vendor
- Dewitts radiator
- No front sway bar
- Stock LS7 block
- Moroso Oil filter
- ARP rod bolts
- ARP crank bolt
- Stock LS2 oil pan
- Z06 rear sway bar
Wow .... you were hauling on that run !
Dave
Dave
Supporting Vendor
Originally Posted by subfloor@centurytrans
Yeah, 3.42 Z06 differential.
Top of 4th at around 7500RPM.
Supporting Vendor
Supporting Vendor
I've won a trophy or 2 there myself.everybody still calls it Cayuga even though new name is Toronto Motorsports Park.my 1970 340 Dart "Swinger" would have put a hurtin on that Chevelle I'm still running there 48 years later.Corvette went 10.20 last time out at Cayuga
Received 1,136 Likes
I grew up near Rochester. We went to nearby Spencer Speedway (1/8) mile EVERY Saturday during the summer, weather permitting. It was a big beer party.
Then there was South Butler on Sundays, a 1/4 mile in the middle of a cow pasture, lol. And the last half or so was somewhat downhill. Haha, oh well it was all fun.
