New C4 Owner
New C4 Owner
Hello all,
Picked up a 93 base 6spd this past weekend. Got it real cheap. My plans are to bring it up to good working order...fluids, pads, fix the stumbling motor, etc. Drive it a bit, then evaluate what to do next. I could just flip it at that point or just put some serious money into it to make it a tolerable street machine but with a heavy bias toward HPDE type stuff.
Anyway, here are a few pics. Got it for roughly half the amount on the windshield from a local Chevy dealer.
Received 19,296 Likes
'20-'21-'22-'23-'24
For around $2500, unless there is a lot of expensive things to fix on the car, you got a very good deal. Welcome to the forum and good luck getting the car back in shape.
So I have been researching most of the last 3 days about LSX swaps. They seem like quite a bit of trouble. I'm seriously considering just having the LT1 built by one of the local engine shops. I assume that I can get a 400hp/400lbft motor for less than the cost of a new LSX.
I would also like to do some drastic simplification of the instrument binnacle/center stack with analog gauges but keeping the AC controls intact. I don't care about music in this car. My Audi is for comfort.
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Welcome to the forum and congratulations on your C4!
The LT1 engine was a good, strong power plant (with the exception of some Opti-spark and oil leak issues that are usually fixable now). With a well developed plan, you should be able to get your 400/400 goals. If you can do most of the work yourself, you can do it cheaper than an LSx swap.
Good luck with your modding.
Pro Mechanic
Received 3,952 Likes
Welcome to the forum!
Congrats. on your C4!
Good luck with your project ideas for it!
Received 1,679 Likes
Welcome to the CF!
