[Z06] Key fob
Key fob
Need help with this. The key fob I have is the one on the lower left side of the pic. The one pictured in my GM owners manual is the one on the top right side with the key that inserts into it. I bought this car with 2400 miles on it, It's always had the older style fob's and they have worked fine. Now I'm trying to replace one so I have to sync it to the car. My car has the slot in the glove box for the remote sync port. But as far as I can tell the remote I have won't even go in there.
What the hell is going on here?? It's a 2007 ZO6. Fairly early production run.
If you have the lower remote on the left its the correct fob for your car. You will need to find one like the one on the left as the key size is different for the trunk. I would try the fob in the slot It should work. The users manual in the car might not be the correct one.
i have an 07. I have the key in the lower left. when I purchased a key for a spare from the dealer I got the key on the right. I havnt programmed it yet or tried to get the key cut to my locks
Thanks for the reply. And that's why I'm a bit confused here. I thought the key on the top of the pic started in 2008 but I guess not. Problem is that I still need to program this new one, not too sure how to do it now.
I've heard those wont work on ours without changing the lock mechanism. The key isn't long enough
Are you thinking that the fob has to snap or plug into the slot, like you would plug something into a cigarette lighter? The fob just rests in the slot, it doesn't really snap into the slot. If it doesn't just slide it with no problem, maybe you have it backwards/upside down because that is the correct fob for the 2007.
meanjoe (03-04-2018)
Thanks for all the help.
I bought an '07 Z06 used and it came with one fob and key like the one in the lower left of your picture. When I wanted a second fob as a spare, I bought one on ebay to match the one I had. Please be aware they come in Driver 1 and Driver 2 versions (number is engraved on the back). I had the #2 one, so I bought a #1 fob. Both work fine after I programmed the new one following manual instructions, although the car will recognize if it is a Driver 1 or Driver 2 fob.
I'm not sure if I understand. You say to be aware that they come in Driver 1 and Driver 2 versions. I don't think they are really 'different' - other than one has a 1 engraved on the case and the other has a 2 on it. That is just for you to identify which one is which. You don't necessarily need to order a #2 fob to replace the #2 fob. You can program another #1 fob for #2 if needed.
I guess it was the **** side of me that required that I buy a differently numbered fob to complement the one I already had.
Thanks for the correction/clarification.
And when finished what # FOB was reported as learned #3???
For those that have bought any used car (not just a Vette) and only got 1 FOB, the first thing going through your mind is, where's the other FOB???
Somewhere in the world there is another FOB that works with your car.
Buying a second FOB and simply learning it to your car has not eliminated the potential problem of someone with your missing FOB driving your car away without anyone questioning it. When you are learning a FOB, you are NOT programming a FOB. You are programming the car to say OK this FOB works for me. Any settings associated with the digital signal coming out of the FOB are stored in the car. Heck, for all you know, there may already be a 3rd emergency FOB learned for your used Vette that you are unaware of. First thing I'd do is carefully read the manual with everything related to "re-learn" get comfortable with the process and do it. That deletes all previously learned FOB's and learns only the ones you have. Starts from scratch. That way, no one else can have access to your car EVER.
