1967 CVT - number on cowl in engine bay
Not real sure what i was doing but I noticed this number on the cowl of my car just under the heater box the RH side in the engine compartment. (Just above the splash pan that bolts to the frame). Could this be original to the car or is it likely something put there in the 50 years its been on the road? I thought i had read something on this but i can't find it if i did.
Once again i need the wizards to input their thoughts.
Thank you for anything you can add.
Received 6,943 Likes
2015 C2 of Year Finalist
thats the job number. numbers went from 1 to 499. you will find that number on each door, behind the dash on the bird cage, the luggage stop, and the bulk head in front of the gas tank
67Sunfire (02-25-2018)
Thank you...
also forgot to say that number should match the number on the tank sticker
