FS: parting out 78 L82 4 speed pace car
I got a 1978 pace car that was involved in a fire. Was going to rebuild car, but decided it was too far gone, so parting the car out to help with my other project.
1.) Super T10 4 speed, with bellhousing,flywheel,clutch,shifter,peda l assemblies,z-bar, and all rods,springs,clips, and driveshaft...1200.oo/bo Sold to Sir Bats
2.)rearend OJ coded(3.70s)....350.oo/bo SOLD
3.)half shafts....100.oo/bo... pair
4.)trailing arms minus calipers...525.oo/bo for pair. pending me getting them removed
5.)L82 valve covers...150.oo(these are striped and very nice. Can paint factory blk if that is correct for your car)
6.)Alt. brackets/restored...40.oo pending sold
7).P.S. bracket...20.00 pending sold
8.)Clutch fan/restored...50.00 pending sold
9.)Exhaust manifolds...100.00pr/BO
10.)Pulleys(crank/w.p)...100.00 restored pending sold
11.)Exhaust hanger, and clamps(under trans)...restored 30.00
12.)wiper arms/restored...30.oo
13.)Front/Rr sway bars, and all hardware(i'd replace bushings)...125.oo restored
14.)Frame with rear bumper cover support, and front end steel. Frame has some rust on the back cross member(easy fix)Rest is solid...300.00 ....gone
The alternator core, and power steering pump are pending. sold
Original L82 engine long block is pending.
I had to bring this car to my house, and have no garage.There is interest in the trailing arms, and the frt knuckles/spindles. Once I remove these parts I will have to cut the car up. I plan to do this this week. I apologize for any delays.
That's all for now....I will be adding more....has good frame....body is damaged, but does have title with body, and matching L82 engine.
Yeah, man life gets in the way,
Anyway, jax is cool no shipping woes,
Can you at your leisure email or text me about all the 4 speed conversion stuff
The13bats@aol.com
407 496 8334
Humm..the shop that builds to suit? You had a sweet mid year car?
The13bats@aol.com
407 496 8334
The13bats@aol.com
407 496 8334
Will you sell the drivers door glass , the headlite switch , pull down switch ( both hold vacume ) center brace for the top dash pad ? How much ? I can drive there to pick up , no shipping needed!
I have been busy with work, so I apologize for the delay. I purchased this car as a candidate to rebuild because of it being a L82 4 speed car, but decided against it. I will have the car here at my house over the weekend. Right now, it's still where I purchased it. Give me a day, or so, and can better access. I will respond in order that requested parts. Thank you!
SPCL FX (03-09-2018)
2.)rearend....350.oo/bo
You mean the 3 doors and the surrounding plastic?....or the actual tub of the car? The 3 doors are there....all hinges rusted off, and the plastic surround is broke. If you want the fiberglass....its fine, and can cut.
