FS: Now available from SCP: C7 Corvette Kooks Jet Hot Coated 1 3/4" Headers
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Give your Corvette the power and sound it deserves with a set of quality 409 stainless steel headers designed and manufactured by Kooks. These C7 Corvette 1 3/4" headers are finished off in a Jet Hot coating ceramic finish. The finish is polished for an impressive shine. Unlike most headers that fade or rust, these Jet Hot coated headers will hold their polish for many years, in fact Kooks backs the finish by a lifetime warranty!
The X-pipe design will help give your C7 Corvette that modern, deep rumble you are looking to achieve.
As with nearly all of Kooks headers products, these are a quick and easy bolt-on application to your Corvette. Did we mention these Kooks headers are not only design in the USA but also built in America?
ABOUT KOOKS HEADERS
At Kooks they have been providing tube bending as well as forming and fabrication of bent tube assemblies, for over 50 years. As a leading provider of parts and assemblies for the aviation and transportation industries, they have developed services that add value to the manufacturing process. Fabrication abilities include tube bending, end forming, boring, grinding, brazing, and welding of a variety of materials. Tube ends can be flared, flattened, swaged, beaded, or formed with a Victaulic groove. Properly forming the ends of the tube is an essential part of ensuring optimal performance of the assembly. They are capable of fabricating assemblies from a variety of standard metals including steel, stainless steel, aluminum, and brass. Inspection and testing capabilities include CMM equipment. If additional finishing and fabrication work is needed, trusted outside sources can be contracted, further simplifying customers’ supply chain. In developing welding and brazing services for the automotive industry, at Kooks Industries, Inc., they put a focus on precision and versatility. We offer a wide variety of welding services including gas tungsten, gas metal, as well as resistance spot welding. Torch brazing is performed in-house while both standard and vacuum brazing are available through an outside partner. For high-volume weldments, 6-axis robotic MIG welding is available. Various non-destructive testing and inspection can be performed in-house and by third-party certified weld inspectors, according to applicable industry standards.
APPLICATION: 2014, 2015, 2016, 2017, 2018 C7 CORVETTE
Order here: C7 Corvette Kooks Jet Hot Coated 1 3/4" Headers
ABOUT KOOKS HEADERS
