Rear Drag pack on Base C6
I am looking to purchase a rear drag pack 15" welds for my base C6 I was wondering what would I need besides a drop spindle also what drop spindles do you guys recommend??
I am looking to keeping my stocks up front and in the future changing them out but dont really want to what would you guys recommend????
You don’t need the “drop” spindles. You need the 15” wheel specific “drag” spindles from either LG or Carlyle Racing. LG has dropped their spindles from ~$1795 to $899 to price match the competition. I’m not sure what Carlyle spindles are made from, but LGs are a special aluminum alloy. If I was buying only the spindles, I would probably go for the LGs. You will also need to grind some material off the bottom of the rear lower control arms to clear the barrel of the 15” wheel. I’m not sure if the 15” Weld wheels can fit over your stock brakes, but I think it may be possible with some grinding on the calipers. If not, then you’ll need new rotors and calipers as well. Carlyle offers a complete 15” drag spindle and brake package for a great price, as well as providing the instructions on where and how to clearance the lower control arms.
Supporting Vendor
On a regular and consistent basis I have better 60ft times than big tire cars with full slicks.
This was from a couple weeks ago.
Great times well I have my old zr1 wheels from my trans am will there be any issues running those wheels?? as far as caliper clearances I would like the easiest transition right now im procharged woud like to swap to a f1x in the future
Supporting Vendor
You still running the Yank 4000 and the Z06 rear?
Supporting Vendor
Most people can get by with a 17 inch wheel setup. They have a good track, want to use a drag radial, etc.
A 15 inch wheel gives you more options, cheaper tires, and more sidewall. If you race on the street, not award winning prepped tracks a 15inch slick will almost always out perform a 17inch radial.
Carlyle has a great kit that has everything needed. If you have a base you can just get the spindles, and rotor, grind your caliper down, and your control arm.
Good luck!
Good luck!
Subfloor I went ahead and did the ZR1 wheels with some hoosiers cant wait to put them on this weekend thank you for the great idea
Supporting Vendor
- 18.5psi measured right before each pass
- smokey burnout, approximately 5-6 seconds, leave the car in Drive and don't worry about trying to hold it in one specific gear
MK 300 (01-22-2024)
Thank you Subfloor I wouldn't of even looked at them if it wasn't for you I know it worked on my transam but since these calipers were larger I thought it wouldn't of cleared. I appreciate your help and knowledge thanks for replying. I was ready to blow 3k dollar on a weld setup which I thought was insane this saved me a bunch of headaches and trouble they also look nice
17" Fits Chevrolet - Corvette ZR1 Wheel - Silver 17x11 (corvettedepot.ca)
I have, based on their "fitment guide" everything they have is 18" up for the C6. I wanted to go with something like this so I'm trying to get any feedback from people who might have tried it.
Corvette Wheel - ZR1 Rim - CV01 17x11 Silver Machined Corvette Rim (oewheelsllc.com)
