Anyone running Long tube headers?
Hey guys,
Just got a C6. Looking for long tube headers recommendations.
I also have a question - I am told they're not legal in CA, although I know a lot of Corvettes have them...so what's the deal?
Some places in CA have inspections only when the vehicle is sold. Also, from what I understand, there's no inspection the 1st 5 years for a new vehicle.
I've heard stories of Porsche owners that have 2 engines, one for driving and one for the smog inspection. So my guess is they're swapping parts for smog inspections or have access to a "friendly" smog test shop. However "friendly" shops are becoming fewer and fewer as the state works pretty hard to weed them out.
When I had a C6Z I ran ARH headers and was very happy with those. You should have the car tuned after long tubes. After 6 years I removed the headers so I could smog and sell the car.
Some of the counties in California are smog on transfer only-like if you own a cabin in the mountains you register it there.Mods are only legal if the come with a California Air resources board executive order exemption sticker.If you get pulled over and the leo thinks you have a modified car you can get sent to the smog referee station.Some guys buy new cars and mod them then sell out of state when its time for a smog test.
I just got a 2008 C6 from out of state. So to register it in CA it's going to get smogged anyway.
My long-term goal was to keep the stock mufflers (NPP OEM dual exhaust), and just install the LTs, X pipe with high flow cats - I thought that recipe would pass the smog.
I am guessing you fell under the 5 years "new car" rule. Help me understand - don't we have to smog the car every 2 Yrs?
I have a 2008 Corvette and half to smog it every two years.
problem with lt's is they move the o2 sensor farther away from the motor than designed.that"s why ca. won't issue a carb # for them.any aftermarket part that is before the cats needs a carb # or they are illegal.
your option are:
1- run them and hope the smog tech is blind
2- run them and switch out to stock exhaust every other year at smog time
3- run ls7 exhaust.they are basicly like using shorty headers so the gain over a base c6 exhaust will be about half of lt's
your option are:
To pass smog you must:
1. Pass the visual
2. Pass the OBD2 plug in test
For #1, you may run into a tech that doesn't know the difference or doesn't care.
For #2, generally aftermarket cats will set off a check engine light for the rear o2 sensors. I've been told that they can be turned off in the tune and still pass, but I can't verify that.
1. Pass the visual
1. Pass the visual
1. Pass the visual
The 2 points you mentioned, about that my focus is on# 2. My understanding was LTs with Hi-flow cats pass smog - otherwise, what's the point of buying them; why not run straight pipes? Almost all the ads and sellers advertise "if you want smog legal you must have hi-flow cats." This is contradicting and confusing
Anything from the cats forward requires an Executive Order (EO) sticker. If it isn't original equipment or have a EO sticker it will fail visual. In fact most smog shops do the visual 1st and if you fail that they won't waste their time on a test.
This tells what vehicles have to be tested and how often:
https://www.dmv.ca.gov/portal/dmv/detail/vr/smogfaq
Here's the database of EOs. If it isn't here it isn't legal to use in a vehicle on CA roads.
https://www.arb.ca.gov/msprog/afterm...es/amquery.php
So anyone telling you their long tubes are ok are lying if they aren't in the database. The STAR (smog test) technicians for the most part don't care what you or the manufacturers says. If it doesn't have the EO sticker it fails.
Wow! Thanks for the replies guys. I thought almost everyone ran LTs It's like the # 2 most popular mod (after the air intake) I mean we have tons of shops in the Bay area that sell/install LTs.
You may be able to not disable the rear O2 sensors and not set a code, maybe someone with LTs can chime in.
Ideally if you can turn off the rear O2s and still get a ready reading on the sensor, that would be your best bet. I've had tuners tell me it's possible, but I haven't verified it.
I am more focused on ensuring the sniffer would pass.
Not so worried about the "visual". Looking from top LTs look very much OEM, and there are shops that don't know/care much about visual. Like I said, nobody ever looked under my C5 (although I was all stock, except the Blackwing).
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
I’m talking full z06 from manifolds to mufflers. It adds HP and sound without worrying about visual.
There is no sniffer anymore for 1999 and newer. So that’s not an issue.
I already have the OEM NPP, so I don't think it's worth getting Z06 exhaust, since Labor would be about the same whether I get LTs or Z06 exhaust.
Thanks!
obd2 plug in now. No sniffer. Visual and plug in only. All they did on my vette last year
