New Katech Billet Transmission Pan for A8 with cooling fins and heat shields, +2qt
Old 03-15-2018, 09:40 AM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
Default New Katech Billet Transmission Pan for A8 with cooling fins and heat shields, +2qt
-Billet aluminum construction
-2 quarts additional fluid capacity
-Integrated cooling fins
-Gold foil-lined exhaust heat shields
-Direct replacement part
-Includes fill level check tube (not shown in photos)
-Transfer magnets from OEM pan
http://store.katechengines.com/bille...-pan-p619.aspx
__________________
Contact:
(e) zach@katechengines.com
Riderover50 (03-17-2018)
Old 03-15-2018, 09:57 AM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes on 2,058 Posts
2015 C7 of the Year Finalist
So, this will stop the limp mode the guys are getting when they drive the car hard at the track?
Elmer
Old 03-15-2018, 10:00 AM
Katech_Zach
Elmer
We are not claiming that this is a singular fix for transmission overheating issues, however it does offer improvement. We are building a C7 Z06 A8 track car now that has this pan as well as additional transmission oil coolers.
Old 03-15-2018, 10:30 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Looks nice. What's a fluid level check tube? Does this allow the checking of the fluid level? I like the drain plug.
Old 03-15-2018, 10:34 AM
Katech_Zach
In the front of the pan there is a spill-over tube. You fill the pan until fluid reaches the level of the top of that tube and starts overflowing it and out the bottom.
Old 03-15-2018, 06:52 PM
383vett
383vett's Avatar
Thanks.
Old 03-15-2018, 07:19 PM
eboggs_jkvl
It's too damn good looking to be on the underside of the car where it can't be seen!
Avanti (03-16-2018)
Old 03-25-2018, 06:13 PM
Taz Golf
Taz Golf's Avatar
Can't wait to see it on my car Jason...looks great !!
Old 04-21-2018, 01:10 PM
bradg33
bradg33's Avatar
Do you have any performance data on how much of a temperature difference the pan alone will make? I've got a non-Z51 Stingray with the A8 and it's getting rather hot on the track. In round numbers, is this good for a 10* temperature reduction or a 50* temperature reduction?
Old 04-23-2018, 01:42 PM
Katech_Zach
No, we don't have that data. We are going by our calculations for heat rejection of the heat sink.
Old 07-16-2018, 07:48 PM
jackpilot
jackpilot's Avatar
And what are those calculations if I may ask? What do you expect to see with the addition of this $1000 piece of equipment. I'm looking for cost vs reward.
Also, do you have any installation instructions? And you mention in an earlier post of this being part of a more involved cooling system upgrade. What other specific items are you adding?
Thanks for your time.
Old 07-18-2018, 02:42 PM
Katech_Zach
Here is our calculation for the simple convection transfer from the trans pan. Keep in mind this doesn't account for things like airflow across the bottom of the car, trans fluid moving across the inside of the pan, or fin efficiency (since heat transfer at the tip will be less than the root).
Old 10-12-2018, 10:14 AM
Checkmate1
Checkmate1's Avatar
Would love some track data with before and after (preferably HPDE).
$1,000 is a huge investment for a transmission oil pan. I am curious on whether merely DEI wrapping the exhausts on the side of the transmission pans will lend to heat deflection and achieve the same goal for a fraction of the price.
I am also curious on the threading of the drain plug on your pan. Would it strip if accidentally torqued too high?
Old 10-12-2018, 11:31 AM
Flame Red
Flame Red's Avatar
Received 1,084 Likes on 656 Posts
Let me first say I am not poo-pooing this product. I would LOVE to get one myself but I have the A8 and don't want to give GM ANY excuse to void my A8 warranty. My A8 was replaced with 100 miles on the clock and it is starting to get the dreaded shutter. But I can tell you that the DEI wrap does NOTHING. I installed the DEI C7 kit on the cats and engine oil line and it did absolutely nothing! So I doubt any DEI wrapping around the tranny will help at all. What did help my A8 greatly is I swapped out the stock fendor vents to the Z06 style and that provided significant tranny temperature improvements even though I am in the FLorida Inferno! I highly recommend that rear vent swap!
I would love this pan but I cannot afford to give up my GM warranty. It is a shame.
GundamX7X (12-10-2018)
To New Katech Billet Transmission Pan for A8 with cooling fins and heat shields, +2qt
Quick Reply: New Katech Billet Transmission Pan for A8 with cooling fins and heat shields, +2qt
