C7 Z06 Tune Help
C7 Z06 Tune Help
I’ve been working with a reputable shop on a remote tune, however some small bugs are still present. Can someone point me in the correct direction to resolve these bugs, or at least confirm these issues can not be fixed?
The issue is that the car doesn’t know where to match the revs. It’ll drop revs quickly while getting into the next gear, & it ends up below the correct RPM for the next gear & it the car realizes this, so it then revs up to the correct RPM.
however the car then bounces around for a bit before settling at the correct rpm.
The other issue is that while NOT in rev match mode, upshifting normally the car drops RPMs quite quickly IMO.
I have to up shift as if I were racing so that I can get catch the correct RPM while it is falling.
Mods:
F1A w/ 3.7” pulley
TSP VVT3
TSP LTHs
alky dual nozzle meth
E85
LMR tank
FYI, I’m not here to shame the current shop, I’m simply looking for assistance as these issues have been present for quite some time & I was hoping they would have found the fix by now.
Thank you all, attached a few logs and the current tune.
EDIT: For some reason CF isn't attaching my tune or logs.
Here is a dropbox link for these files: https://www.dropbox.com/sh/kuytsyhpg...lHjJ3S1ra?dl=0
Mods:
F1A w/ 3.7” pulley
TSP VVT3
TSP LTHs
E85
LMR tank
I’ve gotten a few recommendations on who to contact, I was hoping someone would chime in on what to look for so I can just have the current shop working on it right now look into it.
Thanks for for the recommendations, I’ll keep these handy if i have to go that route.
Received 2,379 Likes
all of your files links are broken
I only looked at "Revision 5 Complete" so I don't know what the other two are.
Fast Torque Exit (is stock) and Driver Demand are not like I would set them.
You're running a MAF only tune and the VVE tables are stock, which I would address.
The blower puts a load on the engine and if not compensated for in the torque model it will pull it down as well.
At first glance your torque model is stock.
I will have to forward this info to them, thank you again.
Don’t be too upset, this is a common situation. I bet all the similarly modded cars to yours drive differently but not everyone takes issue with it. Very easy to write it off as characteristics of the modifications, but today’s ecm’s are powerful and in my opinion anything can be made to drive as good as stock now.....but it takes a lot more time and you may have to pay for that time......
I understand businesses get busy, stuff takes time, etc. I really have no issue with that.
But if you are saying most things look stock, then what really has been changed after 5 revisions? That’s just not cool..
I hear you man. I am not saying "most" things look stock, just a few things and they are things a lot of tuners don't change and get away with it so I am saying don't feel singled out or something, you are just expecting more than the average person and there is nothing wrong with that. 11 years ago I was in the same boat so I taught myself to tune on a 750rwhp 2001 Z06 (and if you remember those cars it took a lot to get to the 700's).
Good luck getting the tune polished up, it can be done, but these ECMs are monsters, I hate them and long for the old days when all you had to do was set spark up and tune the MAF and SD tables, lol. I feel like an old man lamenting the carburator now.
